Question about Goodman CLQ36AR49 Air Conditioner
Compressor noise goodman 3ton 15 seer heatpump model gph3615m41 the compressor is make a continous laboring noise and it's loud.is it a bad valve or the compressor itself, need help
  • 333 Answers
I the compressor is bad it will draw high amps. If the amps are ok then i would look at the valve.
Posted on Jan 18, 2009
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
My heater on my goodman heatpump/air conditioner fan don't come on and it make a loud noise
Compressor will make a sound as refrigerant pressure builds. Could be a few things wrong. With breaker off!!! Check first see if you can spin fan blade outside if moves freely it is okay. If Hard to move Fan motor Bad. Next check what they call duel capacitor remove out side panel it look like these. Top of these should be flat, if it has a bulge on the top capacitor has failed has 3 or 4 leads on it usual 6ca8bc8.jpg
Dec 02, 2009 | Goodman GMS90703BXA Heater
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
The company that installed the unit has gone out of business
Any HVAC service can repair this unit under warranty for parts. A labor charge will apply.
Enter this site and post your zipcode for another servicer in your area.
http://www.goodmanmfg.com/
Sep 28, 2009 | Goodman Heating & Cooling
Is a goodman gsc139421ac a heatpump
13 seer 3.5 ton unit check inside condensing unit for reversing valve. Also open panel and see if it has a defrost board. It is located above the contactor. Rusty
Jun 04, 2009 | Heating & Cooling
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
I can't seem to get my pressures up on a new 3 ton 13 seer goodman? High side 200psi low 50psi not cooling the house
You might have a bad valve on compressor.Close valve on high side and see if the low side pumps down. Of course you should have your gages hooked up.If your low side doesn't pump down you have a bad valve.
Jul 10, 2008 | Goodman Heating & Cooling
Goodman Heat pump
GOODMAN HAS A PROBLEM WITH A FAULTY REVERSING VALVE. THEY IMPORT VALVE FROM CHINA AND ITS NOT GOOD QUALITY, THEY ARE IN PROCESS OF CHANGING VENDOR.
Nov 26, 2007 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
272 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
