Question about LG 50PK750 50 in. Plasma HDTV
LG 50PK750 Plasma has a 1" wide verticle white line right in the middle of the screen and happens on all in puts and I unplugged it for 10 hrs and still is a problem
SOURCE: Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Posted on Sep 10, 2007
  • 6 Answers
SOURCE: Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Posted on Mar 23, 2008
Kindofcheap
  • 241 Answers
SOURCE: 42inch LG plasma TV
well if you could please give out the model nuumber thank you
Posted on Sep 10, 2008
  • 187 Answers
SOURCE: PERMANENT RED VERTICLE LINE DOWN THE SCREEN
Replace the timer control board
Posted on May 27, 2009
SOURCE: I have a 42' LG plasma that has now has a 1 1/2
Own an DU42PX12XC that shows colorful vertical lines over half of the monitor, having only half visibility, sound is good.
Posted on Aug 30, 2009
42inch LG plasma TV
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Phillips Plasma 42" Solid White and Black Line in Picture
Try to check the part on d convergence board.
Thank you
May 29, 2008 | Philips 42FD9954 42 in. Plasma HDTV
TV has a 1 inch dark vertical line on left side of screen, even on "menu".
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 17, 2015 | LG 50PK750 50 in. Plasma HDTV
LG 50PK550 Plasma Single Thin Green Vertical Line
It is going to be one of two basic issues:
1. There is a poor connection somewhere in the set--either with a plug or cable or on one of the boards.
2. There is a board that is beginning to fail causing this.
Either would require a shop and may or may not be worth the cause.
Having seen hundreds of these sets all are more prone to flaky problems than the older sets and average life span is 3-5 years.
Shop I work for 80% of them are 2 years old or less.
If problem began shortly after set was moved or relocated I would lean towards a bad connection somewhere.
Mar 17, 2012 | LG 50PK550 50 HDTV Plasma TV
Samsung 50 in. HPS5033X/XAA colored lines running vertically and won't go away.
How wide are the lines. Do they change width? Where on the screen are they located?Connections on the c boards at the bottom to the panel flex cables or bad c board itself can cause 2 inch wide verticle bar. Before touching these connectors be sure power supply is disconnected from the 2 sustain boards on the sides. If you don't there will be an arc that will destroy the flex cable thus you will have to replace the panel. If C boards or connections don't fix it the replace the plasma panel. If the lines are thin lines then panel is likely bad. Contact Panasonic even if out of warr they may help.
Dec 06, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have a verticle black line about 3 inches wide on my panasonic
Normally when a line appears on the screen of a plasma or LCD it indicates the TV needs repair. There are circuit boards inside the set that, if bad, will cause problems with the picture. The only troubleshooting the manufacturer will offer is to unplug the TV for 30 minutes. If that doesn't solve the issue, the unit needs service.
Call Panasonic at 800-211-7262 to see what they're willing to do for you. If you're under warranty they will service the TV for sure. If you're out of warranty they still might give you a break--they've been known to do that.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 04, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
LG 50PK750 50 in. Plasma HDTV Logo
Computer Repairing
Computer Repairing
