Question about Tomtom GPS
Rds-tmc 4UUC1 says it wont work with current maps on my tomtom one 3rd ed.
I downloaded the most current maps
SOURCE: tomtom one maps
I just had this same problem. Quite strange. I have a Tomtom One New Edition and connected to a Vista Ultimate computer. Here is what I did to fix the problem I was having.
Exited out of the Tomtom HOME application. Went to "Computer" and right clicked the Tomtom drive (was M: for me, could be different for you) with the Red Icon. Selected properties and click on tools. From there I selected "Error-Checking" and only checked "Automatically scan and fix errors for me". It said it found a couple errors and corrected it. I then doubled clicked the icon in the bottom right portion of my screen which looks like a USB plug with a green check mark on it. I selected the drive and clicked stop. I disconnected the usb plug and then used a small tack on the bottom of the Tomtom unit to reset the device. After that, I turned the unit on and all was fine and I could clearly see that an update was applied.
Good luck! They really should have a support bulletin for this as this is clearly a common issue.
Posted on Dec 27, 2007
SOURCE: TOMTOM ONE 3rd edition NO Maps found
noob
Posted on Sep 09, 2008
  • 78 Answers
SOURCE: TOMTOM ONE MAP GREECE
There is in face a map for Greece. Tele Atlas provides mapping solutions for TomTom products, and they do have maps for Greece for the TomTom ONE 3rd Edition. Select the device from the pull down menu on the Map Store, and you will see there are indeed updated maps for Greece.
Posted on Nov 11, 2008
SOURCE: Problem with map. You cannot use this map on this device Western_Europe_1GB
Deleted map from Tomtom device and again downloaded map from Tomtom Home. Device working fine.
Posted on May 18, 2009
  • 25 Answers
SOURCE: TomTom Go 720 map activation
No Maps Found usually means the Application on your internal memory is not the latest one, or the map did not download correctly.
Make sure when you select internal memory when updating your device on home, that you update the application as well.
V8351 should be the latest application for your device.
Posted on Oct 07, 2009
I need the activation code for my TT One 3rd Edition DeviceVersionHW=ONE (v6) DeviceSerialNumber=Y77428B00156 DeviceUniqueID=AKWSN ASCQ2 Maps: Deutschland 605.23957 DE_AT_CH_PL_CZ_Plus...
You may not likely find/get the activation code(s) for your map(s) since your map versions are quite old ... current map versions are 920... Your other option is to purchase a current map from TomTom.
You can go to tomtom.com (and if you haven't registered your GPS device, register the GPS device (on tomtom.com) against your name, etc.,) and purchaseicon1.png a map (of your choice). With this purchase, you will download the map (software and data), and an activation code to validate the map. After that you should be able to use the GPS device (for the purchased maps).
Sep 22, 2013 | Tomtom ONE 3rd Edition GPS
DBA-TMC receivers for TOMTOM
You can't ..... sorry
Aug 10, 2013 | Tomtom GO GPS
The tomtom device prompts me to connect the traffic receiver.How do I do that
This is for the RDS-TMC antenna.
Plug the end fitting on the antenna into the bottom of the Tom Tom. Plug your normal power cable into the antenna.
If it's working, when you turn it on, you should see a new display, narrow, vertical, on the far-right side of the screen.
Oct 30, 2009 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
CANNOT ACCESS TOM TOM TRAFFIC
If you're using a RDS-TMC, then you don't need to go through Tom Tom Traffic. The traffic bar should show up on the right-hand side of the screen, and you're good to go.
If that bar isn't showing up, here's what to do:
Reset the navigator (use a paperclip in the hole on the bottom of the unit). Plug the RDS-TMC antenna into the navigtor. Plug the car charger cable into the RDS-TMC antenna. Turn on the Tom Tom.
Is there a traffic information bar now?
Jul 17, 2009 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
May 17, 2009 | Tomtom ONE 3rd Edition GPS
No maps found error on tomtom 3rd edition
you need to uninstall tomtom home and then reinstall again you can do this at
http://tomtom.com/plus/service.php?=17
this will take you to thevery latest tomtom home downoad
Jan 27, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom 910 RDS-TMC Traffic Receiver
because tom tom uses the bluetooth connection via your cell phone to obtain traffic conditions on the newer verision of tomtoms they use the rds signals
Dec 11, 2008 | Tomtom GO 910 GPS Receiver
Unable to get it connected
Is this the RDS-TMC?
Try resetting the navigator (using a paperclip in the reset hole in the bottom of the device). Then plug it in again and see if anything's changed. Remember that the antenna must be connected to power for it to work.
Are you seeing the vertical display on the right-hand side of the screen?
If the thing is constantly searching but never showing traffic updates, it's possible that you don't live in an area that has active RDS-TMC broadcasts.
Nov 01, 2008 | Tomtom Tom Tom RDS-TMC Traffic Receiver...
I require an update from 7.101 to 7.22 at least to work my RDS-TMCTraffic Reciever as stated on the box that was supplied with the reciever
The problem seemed to be solved when I downloaded the latest update onto my TomTom. Although it was not as the RDS-TMC Traffic Reciever information stated on the box supplied with the system, I was able the recieve a signal form a radio station.
I have been unable to prove the whole system as I have not encounted any traffic holdups to date.
Thankyou for your reply.
Yours Faithfully
G Melville
Jul 06, 2008 | Tomtom GPS
GPS Logo
65 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
