I have an Acer Extensa 5513NWLMi Notebook and my DVD RW is not working i need an driver for the same, can u provide me one
  • danishshiraa Jan 18, 2009
    on the above mentioned address as there is no driver for the Burner
  • 119 Answers
You can download acer drivers here:
http://support.acer-euro.com/drivers/index.html
Please rate, thks
Posted on Jan 18, 2009
I have an Acer Extensa, problem is dvd disc doesn't seem to spin when I load it into slot. Always gives me the no disc detected window. R> U>
first go to the ACER web site and download the lattes drivers for your particular notebook. could just be a driver issue. if that does not work then the DVD drive may have gone bad.
Jun 10, 2011 | Acer Extensa 5420-5687 Notebook
I have an ACER Extensa 4220. My OS is Windows 7 Ultimate 64-bit. My problem is: After OS installation the CD/DVD drive is working well--able to read disc in general, able to install softwares or driver via...
Purchase a new (or used) disk-drive that is compatible with your Acer notebook.
Remove the current disk-drive, and set it aside.
Connect this "alternate" disk-drive, and install Windows onto it.
Then, test the CD/DVD drive -- if it still gives problems, then you have a "hardware" problem with the CD/DVD drive, and trying to make any "configuration" changes within Windows will have *NO* effect.
Jun 01, 2011 | Acer 4220-2346 Notebook
I have acer aspire 4520.I have upgraded to windows xp sp2. The empowering technology does not work.It says " the specified file is not found".I cannot find the empowering technology software...
Acer Aspire 4520 Notebook Technical Specifications:
Operating System Genuine Windows Vista Home Premium Processor AMD Athlon™ 64 X2 Dual-Core Processor TK-57 (512KB L2 cache, 1.9GHz) Chipset NVIDIA nForce 610M Memory 1GB (1GB installed in one of two memory slots) DDR2 667 SDRAM User upgradeable up to 4GB (one 2GB memory card in each slot)* subject to availability of 2GB cards
*If upgrading after initial purchase, one or more of the memory cards provided with the system may have to be replaced with optional larger memory cards in order to achieve the maximum capacity.
Storage 120GB* hard disk drive Integrated variable-speed Super-Multi drive (DVD+R, DVD-R, DVD-RAM):
-Read - 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
-Write - 24X CD-R, 10X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
5-in-1 card reader for optional MultiMediaCard™, Secure Digital card, Memory Stick, Memory Stick PRO™ or xD-Picture Card™
Surely to load XP is a DownGrade. As this notebook is dual core, I would run Vista 64 or better still Windows 7 64.
If you wish to persist with an old system, you require SP3 for XP.That may be available from a software store but is no longer supported by Windows.
Try http://www.notebook-driver.com/laptops-information/acer-aspire-4520-notebook-technical-specifications/ for drivers that you will require to have support from Acer.
Hope that clarifies your situation.
Dec 09, 2010 | Acer Aspire 4520-5582 Notebook
I have Acer Extensa 4620 its dvd drive is not working where should i get repaired and how much will be it costs?
Fix it yourself heres how: purchase a replacment dvd drive heres an example of one you could purchase that will fit your model http://cgi.ebay.co.uk/ACER-EXTENSA-6602-DVR-K15RA-DVD-RW-LAPTOP-DRIVE-7865_W0QQitemZ330344511659QQcmdZViewItemQQptZUK_Computing_LaptopAccessories_LaptopDrives?hash=item4cea1138ab#ht_1313wt_732
Most dvd drives from any acer extensa will fit your model with the relevent bracket, which you will already have connected to your broken one.
ok now veiw the service manual here Service Manual and go to page 57 chapter 3 (67/142) here you will find the section called removing the optical drive module. its really simple just follow the instructions and pictures carefully.
Hope this Helps! Please Rate!
Nov 27, 2009 | Acer Extensa 4620 Notebook
Driver support
Pull the optical drive to see manufacturer and model number. Go to their web site for drivers.
Mar 11, 2009 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 notebook dvd-cd rom doesn't read my dvd. i think i uninstalled driver. how can i find dvd writer driver for my notebook?
go to device manager under System Properties. Locate DVD/CD Drives, expand it, select your drive, right click and then left click on properties, select the General tab and check the state of the device IT SHOULD indicate the device is working properly, if so or if not, select the Driver tab unomstall the driver, reboot, see if Windows will reinstall the driver as it should recognize the device as a new drive. If not return to the device manager and reinstall the driver.
Feb 19, 2009 | Acer Extensa 5620-4020 Notebook
I can't finalize a DVD on my Acer Extensa 4420. I follow the instructions, but the DVD is only readable in my Extensa, not in any other system.
Have you got a dvd/rw drive or dvd rom drive,
A DVD/RW drive will write DVDs
A DVD Rom Drvie will only read DVDs
If its a DVD/RW then remove device and reinstall
if you need more info please tell me what OS your using and make and model of your machine or pc
Thanks for your request.
Jul 20, 2008 | Acer Computers & Internet
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
I wish to download the Software drivers for Pioneer DVD RW
May 24, 2008 | Computers & Internet
Computers & Internet Logo
371 people viewed this question
David Payne
David Payne
