Question about Roper Dryers
Roper Dryer REX3615EWO
Need a operation manual for this dryer
  • 159 Answers
SOURCE: roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Posted on Aug 22, 2007
SOURCE: Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Posted on Jul 10, 2008
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
  • 105 Answers
SOURCE: I have a Roper Dryer Mod# REX5634KQ1. It just
There is a "one shot " thermostat that is probably blown. Part number 279816 which is a two piece kit. The part is located at the top of the heater housing.
Posted on Apr 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: how to replace a dryer belt on a roper dryer
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps Please do not forget to rate me Thank you
Posted on Apr 09, 2010
My Roper dryer heats way too much. I have changed the t stats ang cleaned lint and exaust vent.
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 10, 2011 | Roper RGX4634KQ Gas Dryer
Need a free manual
Are you needing just the operating manuel or technical manual Go to whirlpool.com thanks
Jul 08, 2011 | Roper REX4634KQ Electric Dryer
I have a roper dryer and there is no heat. I changed the heating element and I still have no heat.
thermal fuse, for test purposes only (DISCONNECT POWER) tape the two wire together run dryer it will heat, then order the correct fuses and replace them before operating dryer;
http://www.applianceaid.com/thermo.html
Feb 16, 2011 | Roper Dryers
My roper dryer want dry
Look for air restrictions:
After doing a thorough clean and the dryer still acts up then consider this:
I have a service manual and more here
Jan 15, 2011 | Roper REX4634KQ Electric Dryer
Does not turn on and it's plugged in and i triped the breakers......
http://www.hammerwall.com/Manuals/Roper/Description/REX3614KW/Roper%20Electric%20and%20Gas%20Dryers%20Manual/L0101032/
Hi whatever the cause you are going to need a service manual, the links above and below, are top, user manual, below your service manual.
Many dryers are the same, internally, simply rebranded..
http://appliancejunk.com/forums/index.php?topic=2931.0
Jul 14, 2010 | Roper REX3614KW Electric Dryer
IT RUNS BUT DOES NOT HEAT
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 02, 2010 | Roper Dryers
Roper gas dryer does not heat.
If the ignitor is not powering , go to the switch. That has to send power to the ignitor, then on to the gas valve.
Jul 22, 2009 | Roper RGX4634KQ Gas Dryer
Roper coin operated washer and dryer with no keys
call A locksmith to drill out the lock then re-key the machines
Dec 19, 2008 | Roper RAK2751WWH Top Load Washer
Dryers Logo
64 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
