Question about Cuisinart DCC-1200 Coffee Maker
Self clean is blinking how do i clean my cuisinart coffee maker
4 Suggested Answers
SOURCE: cleaning my coffee maker
can the carafe of the stainless steel coffee maker go in the dishwasher?
Posted on Apr 20, 2008
  • 85 Answers
SOURCE: self clean light keeps blinking
Hello guindonlm,
I recently had this similar problem. Try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
  • 85 Answers
SOURCE: How to use the self clean feature of this coffee maker
Hello gerilind,
It is recommended to clean the system out about once a month with a 2parts water to 1 part vinegar, translated it is 8 cups of water and 4 cups of vinegar. Press the self clean button and the brew switch. Rinse with fresh water one or two times.
Should work for you. Don't forget to check the filter stick in the back left of the unit. Pull it out and remove the clogged carbon filters. Shine a light into the bottom of the cavity and clean out the debris left behind. You can get replacement carbon filters on Amazon, they are inexpensive. Reinsert the stick. Your coffee should be back to tasting excellently in no time at all.
I hope this is helpful to you. If it is, please leave positive feedback for me. I will very much appreciate it. Kind Regards, NormanZ :o)
It's telling me to self clean?? Can't find manual
Fill water reservoir with 1/3 carafe distilled white vinegar, 2/3 carafe water and hit the self-clean button - it will take about 35 mins to complete. When it is done, it will beep like it normally does when brewing regular coffee. Self-clean light should go off after this. If it doesn't, simply unplug the machine for 20 minutes or longer. The manual is available for your inspection on the Cuisinart website.
Sep 20, 2009 | Cuisinart DCC-1200 Coffee Maker
Please give me step by step instructions on how to clean Cuisinart Coffee Maker, Model #DCC-1100. Thank You!
Jul 28, 2009 | Cuisinart Coffee Makers & Espresso...
Self-clean button keeps coming on
Unplug the coffee maker for 1 hour or longer - it wil lreset the machine, and turn off that self-clean light.
Feb 07, 2009 | Cuisinart DGB-600 Coffee Maker
Self Clean Button
Unplug the coffeemaker for 1 hour or longer - it should reset the coffee maker and get rid of that self-clean light.
-Tha Mp3 doctor
Jan 24, 2009 | Cuisinart Coffeemakers
Cuisinart coffe maker self clean
I found the manual here http://www.retrevo.com/s/Cuisinart-DCC-1200-Coffee-Makers-review-manual/id/890ci052/t/1-2/
Oct 28, 2008 | Cuisinart DCC-1200 Coffee Maker
After cleaning the unit DCC-1100 4 times, the clean light is still blinking---what is the next step????
Your coffeemaker is clean after a maximum of 3 cleanings. Unplug the coffeemaker for an hour. When you replug it, the self-clean light should have gone off.
Apr 15, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Cleaning my coffee maker
Mar 19, 2008 | Cuisinart DCC-1200 Coffee Maker
Self cleaning coffee maker
Unplug the coffeemaker for one full hour, and the self-cleaning light will go off.
Mar 01, 2008 | Cuisinart DCC-1200 Coffee Maker
Self clean feature on coffee pot
here is the link to the manual http://www.cuisinart.com/share/man/25_man.pdf page 8 - looks like you have a calcium buildup - descale overnight using vinegar/water 50% if the self clean feature is not able to deal with the problem. hope this helps :)
Mar 10, 2007 | Cuisinart DCC-1200 Coffee Maker
Self Clean Button
Hello there,
Not sure if you have solved the problem. I have found the actual owner's manual by researching on line... Hope this helps. Here is the link...
http://www.cuisinart.com/share/man/30_man.pdf
Marilyn
Jan 16, 2007 | Cuisinart DCC-1000 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
266 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
