6th sense front loader washes normally but conditioner will not empty out of the dispenser
  • Washing Mach... Master
  • 17,130 Answers
Please try and reset the power so that the program controller will reset and come back to settings. Also check the dispenser tray for any block within , if so clean and refill.
Since all these fuzzy logic works on the processor controller if the problem remains it can also be related to an error in the program.
Posted on Dec 31, 2012
SOURCE: whirlpool 6th sense front loader awm 8121
my whirlpool 6th sense will not start all lights and power i think that it is the door sensor at fault? The green light door locked light is not on.
Posted on Aug 17, 2008
SOURCE: washing machine creda front loader
I had the same Problem on a 17112e Creda, I took the top off and using a torch located the red plastic door release mechanism, I then pressed a white button in the centre of it and the door released. I believe that the washing machine was overloaded and auto cut out. I reloaded the machine with fewer items and it is now working.
Posted on Jan 30, 2009
scottludwig3
  • 4 Answers
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
Posted on Nov 17, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
  • 6277 Answers
SOURCE: getting FE error on our
I suspect that stands for 'Filter Error' so I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 19, 2011
Testimonial: "I can only say a big Thank You for your kind help and prompt assiistance..it s a flter problem and cleared it off..back to working..Thanks a ton John."
My whirlpool 6th sense front loader has stopped whilst full of water, half way through a wash. Have emptied machine, Still no power, machine wont turn on.
Hello Janine Gooch,
Went out on our internet trying to find your trouble shooting guide (typically in the OWNERS MANUAL)...
Finally ended up in AU ... No luck.
(September 9th is only 6 hours old here (SF Bay area)).
Your local peers have NOTHING NICE to say about that machine... particularly the CONTROL BOARD:
Whirlpool WFS1071BD Question and Answers
Hope this helps (says top load... shows front)
Carnac the Magnificent
Sep 09, 2017 | Whirlpool Washing Machines
Wanting a user manual for whirlpool 6th sense wfs1071aw front loader washing machine please
go google and type in--operators manual fro whirlpool washing machine model wfs1071aw --- and down load the pdf version
Jun 12, 2017 | Whirlpool Washing Machines
6th sense washing machine showing fault dL. Any ideas ?
Sometimes faults mean bad circuit board. for (front loaders)
Feb 11, 2016 | Washing Machines
How do I increase water level in my wfxd8400uc?
I get this complaint a lot from home owners , I take it you have just got your first front loader washer , and you don't think it adds enough water to wash anything , this is the water saving feature of front loaders
but a simple test I tell most folks to do if they think there water level sensor is not working right
set washer to auto load sense on water level , normal wash cold water, permapress add nothing to drum completely empty! no soap unless you have a auto soap dispenser then it wont start to you add some and close door
start cycle wait till fill is complete just as it goes to agitate stop cycle (plug can be pulled for this if buttons have locked out )and open door see if water level is two fingers wigth under door seal , if its close your ok if it's a long way off then contact a repair department to look at auto sense water level
May 07, 2015 | Washing Machines
Washing machine a whirlpool 6th sense front loader and it spins super fast and out of control. Cheers
Check the clutch and braking system. You will almost certainly need a part breakdown but the unit is not meant to spin without restriction. There may also be a q&a from manufacturer that will tell you exactly which parts to replace.
Mar 08, 2015 | Whirlpool Washing Machines
I have owned our washer for seven years Why doesn't the bleach dispenser empty?
is it a front loader or top loader? what is the model number? normally you have 3 or more water inlet valves 1 for cold water, 1 for hot water and one for either fabric softener and or bleach, id say (without any specific info) that it is simply a jammed/faulty water inlet valve, or if its a front loader you often get this problem if the water pressure isn't high enough to create the siphon in the dispenser, i dont know why they set up the softener dispenser on front loaders as a siphon when the pre and main wash just wash through normally
Sep 27, 2014 | LG Washing Machines
Whirlpool AWOE 9559B 1200rpm 6th Sense Washing Machine, 9 kg instruction book lost; can you provide me with a copy please
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Jan 23, 2011 | Washing Machines
Whirlpool 6th sense front loader awm 8121
Jul 18, 2008 | Whirlpool AWM6100 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
