Question about Xerox Phaser Office Equipment & Supplies
Xerox phaser 7800 startup - Phaser Xerox Office Equipment & Supplies
5 Suggested Answers
faxman789
  • 297 Answers
SOURCE: Xerox Phaser 6110MFP reports FM_IO.c 172 ROOT during startup
Also make sure you have the machine plugged directly into the wall outlet...some surge protectors or multi-outlet strips won't allow sufficient power to properly boot up and run the machine !
Posted on Jan 17, 2009
  • 110 Answers
SOURCE: Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Posted on Jul 24, 2009
  • 141 Answers
SOURCE: I have a xerox phaser 8500. At startup it states
How could this be helpful with 2 thumbs up? The printer in question is a solid ink printer, not a laser printer. The ink is in solid sticks, not a cartridge full of toner.
Sometimes, the ink sticks get jammed up in the chute. Poking at them, sliding them up and reseating them may solve your issue. If you're using non-Xerox ink, it may not be registering that there is ink due to the improperly shaped sticks. However, I believe you would be getting anothe error if this was the case.
Posted on Dec 24, 2009
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
Xerox phaser 7800 rebooting all time
Most likely cause is corrupted software which requires an alt boot which requires the Xerox laptop to reinstall.
Apr 09, 2016 | Xerox Office Equipment & Supplies
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
Engine failure
Hi Zelwe Mwanza
show me error code pls
Dec 27, 2013 | Xerox Printer Division Xerox Phaser...
How to fix problems with electric contact of a xerox phaser 7800dn
Go to the Xerox website and read up on your model. Also see if there is a fuse blown between the power cord and the system itself. Maybe the transformer has died. and needs to be replaced. That happens a lot with devices with 'step down' transformers combined with the electric cord as opposed to transformers built into the device.
May 31, 2013 | Xerox 7800/DN - Phaser 7800dn; 12 X 18...
My Photoshop sends a print job 100 times to my Xerox 7800 instead of once for 100 prints.
I also have this issue running a xerox docucolor 550 and PS-CS6 the only soloution i have is to save the file as a pdf and send it from firey comand center if you are running a firey server command center is available from xerox website
Sep 11, 2012 | Xerox Phaser 7800GX LED Printer - Color -...
Phaser 8560N prints multiple pages when powered on
This was due to the TFTP (PXE) setting on the printer set to on. No more wasted paper at startup/wakeup after changing setting to off.
Jan 12, 2010 | Xerox Phaser 8560N Laser Printer
Dec 10, 2008 | Xerox Phaser 6110 Laser Printer
200 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
