Lansing altec vs2521 wiring connection
DIN socket wiring connection to sub woofer
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
SOURCE: Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Posted on Jan 17, 2008
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
BNUTZBCRAZY
  • 130 Answers
SOURCE: Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Posted on Jan 15, 2010
Marinmeister
  • 11 Answers
SOURCE: ALTEC LANSING-VS-2521 SUB WOOFER AND LEFT SPEAKER
you probably messed something up in the subwofeer amplifier box, try taking them to a repair shop, or at the guarantee place.
another solution would be: you could try and fix them yourself but i don't recommend it.
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
Ah i have altec lansing acs 45.1.the problem is i dont know how to wiring.can u pls help me.ynx
ok first plug run a1/8 two sided head phone jack[male] from the computer to sub woofer you should have two imput jacks makes no differance ok the left sat speaker has a 6 pin din plug round looking plug insert into subwoofer and then plugac cord in the wall you should be good togo "note right sat speaker is attached to the left good luck
Nov 16, 2010 | Altec Lansing ACS 45.1 Computer Speakers
VS2521
I found that one of the pins of the plug connecting the sub-woofer was bent and the plug was not seating properly deep in to the slot. Every pin has a specific task to the sound system, it seems. I set right the bent pin with a long needle gently and re- plugged in to the woofer's slot. After that every thing works amazingly. All it requires is patience and application of mind for a while exclusively focused on the problem.
Thanks and regards
M. Narayanan
Jan 15, 2010 | Altec Lansing Audio Players & Recorders
How to connect
Check the wires.
One wire should end with a thin green pin.
Connect the green pin to the green socket on your computer.
If there is a black pin, you have a sub-woofer, and the black pin
connects to the black socket on one of the speakers.
Connect the wire with the 2-prong silver plug to AC power, e.g., to a power-bar.
Test the speakers.
Nov 25, 2009 | Altec Lansing XA2021 Computer Speakers
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Sub Woofer to Sound Dock
Well if you are talking about the iM600 sounddock from Altec Lansing, the short answer is no. If you want better bass from an IPOD docking system you'll need to buy an expensive component from say Scandyna Dock or you could build one yourself. You would need an integrated amp or a complete system like the NAD C71. This would allow you to plug in a self-powered sub.
Dec 01, 2008 | Apple iPod classic MP3 Player
Altec small speakers
Doesn't look like they make that anymore.
May 25, 2008 | Altec Lansing Multimedia Computer Speakers
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
 Grubhead
Grubhead
