Lennox g26-75 fan not turning on in automatic mode
Recently replaced the Johnson ignition control module with Lennox 30W33 OEM Ignition Control Kit with a new flame sensor. It cured the cycling problems, but now the fan doesn't go on in automatic mode after the furnace fires up. After a few minutes the burners go out. When I put the fan in manual mode, everything works fine. What's up!!
  • 85 Answers
SOURCE: Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Posted on Dec 09, 2008
johnsonr1
  • 91 Answers
SOURCE: lennox lf24 garage heater, starts then shuts down.
Here is a link to the manual for your unit heater:
http://tech.lennoxintl.com/C03e7o14l/mk6x6w5J5/503526e.pdf
The 4 flashes is a high limit or roll out switch is open. There are 2 or 3 little brown or black button looking switches with a little button on the top and a wire attached to each side. Press the button on each, you may hear a slight "click". If you do, that is the one that was open. Hope this helps.
Posted on Nov 04, 2009
  • 215 Answers
SOURCE: lennox intermitent flame problem
Yes the flame sensor is not allowing the ignitor to start, you will need to remove the flame sensor, and clean the black carbon build up from the stem of the flame sensor, replace the flame sensor and turn the furnance back on, this will correct the problem.
Posted on Dec 14, 2009
SOURCE: lennox furnace 17 yeanrs old. flame comes on and
I have a Lennox G40UH furnace. The burners fail to ignite about every 5th time. The furnace will try to ignite the burners then shut down. Once in a while the temp will drop down to 62 then fire up. I have only gotten a Diagnostic code once "Watchguard - burners fail to ignite" once I shut the power down and it started.
The furnace is clean, 5 years old, the flue is not clogged.
Posted on Jan 03, 2010
SOURCE: I have Lennox pulse 21 control module light goes out
If this is a high eff model, check to make sure the intake vent is not plugged.
Posted on Jan 18, 2010
Lennox 80 MGF furnace heat only. Both diagnostic lights are indicating everything is ok with the ignition control but the furnace main fan runs continuously. The fan is on automatic at the stat
So no heating just blower? If you have a g wire on the tstat remove it first. Then possibly a stuck relay. Obviously if the blower stops when g removed the tstat is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 14, 2017 | Heating & Cooling
Lennox g26q3
electronic ignition or pilot type? assuming electronic ignition, check the airflow sensor for dirt in the peto tube, or a defective sensor, if you hear the high voltage click but have a failed ignition chec that the pilot is being lit, and that the thermopile/infrared sensor is good. one of those is your problem.
Mar 23, 2014 | Heating & Cooling
Lennox troubleshooting
Your control may a defected relay to the blower under heating mode. If that is the case you will need a new control board or replay.
Feb 05, 2014 | Heating & Cooling
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
Lennox gas furnace G21Q4/5-100-1 sometimes won't kick on
Hi check out the flame senser is clean also jump ou tthe pressure switch see if it lights when you do this , igntion modul is just a box with some push on wires just get the right one the info is all on the module
Feb 16, 2010 | Heating & Cooling
No spark Ignition, no gas release from the valve.
I would replace the intermitant spark ignition module if it did not produce a spark from the spark terminal to ground if held 1/8" away. Honeywell makes a universal replacement. I think it is either a S8610U or S8900U.
Jan 31, 2010 | Heating & Cooling
Jan 17, 2010 | Heating & Cooling
Need wiring diag for johnson control #G770-RJA-1
Is this on a Lennox gas furnace? If so you may be able to get one from lennox. Imay have one at work, but I won't be back there until Monday. bryan@reedwrightheating.com
Nov 19, 2009 | Heating & Cooling
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
