My hak330 only spins in one direction and wont lift
  • Washing Mach... Master
  • 17,130 Answers
Possible there is no output from the controller and so to the motor drive to reverse the motion.
Remove power for sometime to confirm.
Posted on Dec 31, 2012
Detrola record player wont spin, even after moving arm to far right.
I suggest you lift up the turntable matt and see if you can see a belt, which has either broke or come off. You might need a new belt!
Mar 22, 2013 | Audio Players & Recorders
NANO HURCULES UNBREAKABLE/TOP BLADE SPINS WONT FLY
One of the motors worn out,binding shaft,damaged gears.
Feb 19, 2013 | Toys
Maytag Performa washer drum turns with agitator. Also the brake doesn't stop the drum at end of cycle or when cover lifted.
The first thing to check is the clutch. It's supposed to lock the inner tub and drive the transmission (agitator) when the motor turns in one direction, and spin the tub when the motor turns in the other direction. It's also possible the agitator drive shaft coming out of the transmission and the concentric tub drive shaft are frozen together (worst case) - this is usually caused by a bad bearing seal allowing water to leak into the shaft.
Lifting the lid during the spin cycle should disconnect power to the motor - maybe what you see is the tub continuing to spin because the transmission is acting as a flywheel. Either that, or the lid switch actuator is not working properly.
Nov 27, 2010 | Washing Machines
Gw 612 washes ,drains wont spin fault comes up as on off off off on
Hi just read your posting.Now the problem you might have, and I have had before, is the motor is not turning the bowl far enough when it is starting to spin and therefore the machine thinks the bowl is not turning.To get your machine spinning 1st undo the 2 screws under the lid so you can lift the hob up to see the bowl.Select a spin cycle and hit start while you are holding the hob up enough to see the bowl.The reason for lifting the hob instead of the lid to see the bowl is if you lifted the lid the machine would not work because of the lid switch.Now when you are holding the hob up to see the bowl make sure the lid is closed so the machine will work.Now once you have started the spin cycle you will see the bowl turning one way then reverse and turn the other way.While you are holding the hob up when the bowl turns in 1 direction help turn the bowl in that same direction with your hand.Once the bowl reverses help turning it in that direction also.This will make the machine register that the bowl is loose enough and will kick to spin.Once it is spinning let it spin for the cycle and you should be fine.Please reply for further help if needed,Good luck
Jun 16, 2010 | Washing Machines
The top wont spin and the bottom will
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only
one way.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of
the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator
should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
May 29, 2010 | Kenmore Washing Machines
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
Wahser wont run spin cycle.
Door switch is probably bad or connection is loose. Remove the top cover to gain access to the switch.
David Le
Apr 21, 2009 | Kenmore 22422 Top Load Washer
Lama v3 spins counter clockwise with no lift off
WOW! I have experienced the same spinning action . . all new parts etc. I have repaired 6 Coco's but this one has ate my lunch . . . when you power up it spins to the left . . . the more throttle the faster it spins . . have changed the 4 and 1 also and adjusted . . . over and over . . . does the 4 in 1 control the rudder action?
Jan 30, 2009 | Esky Honey Bee King 2 RC Helicopter
Maytag Washer, LAT2300AAE, won't spin
ok lets see here;your transmission can go in two directions.if you turn the middle pully one way it will agaitate if you turn the oppisit direction you can watch [from under neath]the brake raise as the cam seperates and lifts the brake.now with the brake lifted ,your tub should spin.if its not lifting the brake you need a new center pully kit[i have had to do many]it comes with washers ,bearings and cams.if the brake lifts and your tub still wont spin you may have a pice of clothing between the two tubs[i had that one to,many times]i hope that helps.you can email thru fixya if need more advice God bless ,tom
Jan 26, 2009 | Maytag Dependable Care LAT9706
Washing machine not spinning
You may very well have a frozen brake located at the bottom of the transmission. Take the belt off and turn the large wheel in both directions. The wheel should turn easy in one direction and tight in the other. We are concerned with the tight rotation. Turn the wheel by hand. Directly above the wheel is the brake. Watch to see if the brake lifts up and turns. If not then the brake will need serviced.
Jan 12, 2008 | Maytag Performa PAV2200
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
