Question about Gateway MX8734 Notebook
What is the max ram I can install on my Gateway MX8734
I have 2 2 gig ram chips when I install both of them my computer will boot. If I pull either one out it biits just fine.
  • Gateway Master
  • 32,281 Answers
This model Gateway can support 4Gb of RAM.
The RAM you installed may not be compatible with each other.
Use RAM of the same make and speed.
Posted on Dec 31, 2012
3 Suggested Answers
ErusTownsend
  • 592 Answers
SOURCE: gateway mx3222b laptop ram upgrade problem
your computer does not support 1GB memory sticks. The max memory for that system is 1GB which would be 2 sticks configured as 512MB
see below for the specs (i bold, italics and underlined the main part)
Processor Intel® Celeron® M Processor 370
1 MB L2 Cache | 1.50 GHz | 400 MHz FSB Display Screen 14-inch Widescreen Ultrabright™ WXGA TFT Chipset Via VN800 Memory 256 MB DDR2 (1 × 256 MB) SODIMM
Total slots: 1 DDR2 slot | Available slots: 0 DDR2 slots
Expandable to 1 GB Video S3 Graphics UniChrome™ Pro IGP
Up to 64 MB shared VRAM Audio AC'97 2.3 Compliant Hard drive 40-GB 4200 RPM hard drive Optical drive DVD +/- RW Multi-Format Double Layer
Write maximum: 8X DVD+/-R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 24X CD-R and 16X CD-RW discs
Read maximum: 24X CD-R/RW/ROM, 8X DVD-R/RW/ROM, 4X DVD+/-R DL, RAM discs Media Reader 4-in-1 Digital Media Manager
Secure Digital™, Memory Stick®, Memory Stick-Pro®, and MMC™ Modem 56K ITU V.92 ready fax/modem Network 10/100 Mbps built-in Ethernet
802.11g integrated wireless (up to 54 Mbps) Interfaces
  • 2 - USB 2.0 ports
  • 1 - VGA external connector
  • 1 - RJ11 (modem)
  • 1 - RJ45 (Ethernet LAN)
  • Microphone jack
  • Headphone jAck
Pointing device Touchpad with vertical scroll zone PCMCIA 1 - Type I or Type II; Card Bus Battery 6-cell Lithium-ion Dimensions 1.1 to 1.24-inches (H) × 13-inches (W) × 9.7-inches (D)
28 to 32 mm (H) × 330 mm (W) × 246 mm (D) Weight 5.01 pounds
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
Chipset Via VN800
Expandable to 1 GB
Interfaces •2 - USB 2.0 ports
•1 - VGA external connector
•1 - RJ11 (modem)
•1 - RJ45 (Ethernet LAN)
•Microphone jack
•Headphone jAck
Weight 5.01 pounds
Posted on Mar 03, 2010
Testimonial: "very helpful , many thanks "
joegoldman
  • 335 Answers
SOURCE: MT3705 Gateway, what motherboards will work with
You don't get different mainboards for laptops.....sorry. It's not like desktop pc's where pretty much any mainboard will fit. And even if you could, it's not really going to improve things, as you are using the same speed cpu. Your laptop has 2 ram slots. That's the most you will see on laptop mainboards.
Adding ram is probably the best bet. That laptop shipped with 1 gig of ram.....which is not enough for Vista. I bet it's quite slow. Vista wants 2 gig of ram to be happy, and 4 gig to really motor along. Laptop ram is cheap for that machine, so check it out. Ram is not expensive, and will give you an immediate, very noticeable improvement in performance.
Hope this helps. Post a comment and let me know how you make out
Posted on Sep 05, 2009
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
MT3705 Gateway, what motherboards will work with this laptop. I want to upgrade this laptop, so i want to get a motherboard able to really max out my ram but still use this chip set and everything else on...
Sep 04, 2009 | Gateway Computers & Internet
Need to know how much RAM system can handle
2GB max is the amount of RAM this machine can handle according to cnet reviews about the machine.
http://reviews.cnet.com/desktops/gateway-e-4000-series/4507-3118_7-20824814.html?tag=mncol;psum
May 24, 2009 | Computers & Internet
Want to add memory to Gateway 700x
Upgrading RAM on your Gateway 700X (DDR) Computer is easy, Gateway 700X (DDR) Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. RAM Type, and comes installed with 512 MB (removable) of RAM.
You can upgrade your Gateway 700X (DDR) Computer to up to a maximum of 2.0 GB RAM, the Computer has 4 sockets to install RAM, already with 512 MB (removable) standard RAM installed. For best Computer performance use the maximum amount of allowed RAM per slot for your system.
Dec 08, 2008 | Computers & Internet
Adding ram
Supported RAM TechnologyDDR SDRAMRAM Installed ( Max )0 MB / 2 GB (max)Supported RAM SpeedPC2100, PC1600, PC2700The above is the specification for RAM for your M/board
It can take up to 2Gb ram 2 X 1GB sticks you may have to change BIOS settings aand your computer will definitely run fasterPlease give me a FIXYA
Sep 13, 2008 | MSI KM4M-V KM400 SocketA 333FSB 2DDR...
Gateway M-6823 Notebook memory
The only reason for this is your laptop only support up to 1 GIG of RAM or 2 pieces of 512 RAM you can check this link for that specs of this laptop http://support.gateway.com/s/Mobile/2007/Tempest/1014768R/1014768Rsp4.shtml
Hope that helps............
Aug 08, 2008 | Gateway Computers & Internet
Ram For a Gateway 450Rog
The maximum memory size for this laptop is 1 Gig of memory.
You can see for yourself at this link.
It's a pleasure to be of help!
Lolita
Jun 16, 2008 | Gateway 450ROG Notebook
Gateway E4100 Mid Tower RAM install
no need to install RAM in pairs.
you can buy and install memory but it should be the same model that you have now e.g. DDRII RAM Modules.
you can max out the RAM 4 gigs
Mar 30, 2008 | Gateway Sb-4100-A PC Desktop
Open Questions:
See all Gateway MX8734 Notebook Questions
Gateway MX8734 Notebook Logo
141 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
