Question about Bialetti Moka Express 6-Cup Coffee Maker
Moka spitting With almost a new maker and with an older model I get a good start and the coffee rises well. At about one third full the mmacine starts to spit plenty of steam but no , or very little coffee. If I leave it it goes on spitting and would continue for a long time until it has exhausted all the water as steam. If I take it off the heat, cool the outside and include the valve under the flow of cold, then replace on heat it rises as it should. The valve is clear, I don't pack the coffee too tight, the seling ring is new and well screwed down and everything clean. Is it a question of too high a temperature perhaps. others I speak to have had a similar problem but can't find a solution. I have used these machines for 30 years and not until recently ever had this problem;
2 Suggested Answers
SOURCE: Mukka Express spits out coffe from the screw section & steam valv
it did that to me too, so I reduced the amount of milk to the indicated level inside. No more mess after that.
Posted on Feb 18, 2009
Coffee won't come up
Obviously, the filter is clogged up. Buy a replacement.
May 17, 2014 | Bialetti Moka Express 6-Cup Coffee Maker
Hello! I change the rubber sealer to my Bialetti 12 cup yesterday and since then the water stays in the bottom and does not rise to the top. The sealer is properly put in. I have not done anything...
This happened to me, too....the gasket needs to be broken in so that it seals properly, which will happen once it's been used several times. In the meantime, just tighten the pot together extra tight and that will help to seal the gasket properly. After several uses, you won't have to tighten it so much and can go back to how you've always done it. I hope this helps!!
May 19, 2010 | Bialetti Moka Express 6-Cup Coffee Maker
Barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Jun 28, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Weak coffee is the result of brew
Since it is "brand new out of the box" check for plastic burs (pieces of plastic improperly hanging around
openings along flow of water) throughout unit, and use more coffee than recommended for your taste of
what a good cup of coffee should taste like, since that varies from individual to individual. If you are using
packets, try using TWO. Experiment, Experiment...........
Apr 17, 2009 | Regal Ware 15-0264 Polished Aluminum...
Coughing coffe
Try a lower flame and screw the top to the bottom as tightly as possible.
Mar 17, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
How much coffee?
Fill it as full as you can with fine ground coffee. I cut the resulting brew with an equal amount of boiling water. Called an "Americano" in Italy.
Jan 06, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Weak coffee
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Jun 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Espresso C15---weak coffee
Apr 28, 2008 | Jura Capresso C1500 Espresso & Coffee...
Bialetti sputtering after gasket replaced
Flame is too high and the top is not screwed tightly enough to the bottom. Also make sure there is enough fine ground coffee in the funnel.
Feb 20, 2008 | Bialetti Moka Express 6-Cup Coffee Maker
Bialetti Moka Express 6-Cup Coffee Maker Logo
41 people viewed this question
Top Bialetti Coffee Makers & Espresso Machines Experts
Ross Keen
Bill Boyd
carlos parada
carlos parada
Level 1 Expert
Are you a Bialetti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
