Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote will not close door
The remote opens the door fine, but when you press the button to close it just move about a half inch.
    Champion:
  • 244 Answers
Safety beams are blocked or you have wall console in lock or vacation mode.
Posted on Jan 18, 2009
I have got a Eazy Lift Mk 11 garage door unit. When i opened it this morning it went just half way and stucked.When i press the remote the motor is not working and the motor is now 4 years old. What c
2 steps for you... first put new batteries in the remote. next trip the door mechanism by pulling on the rope. that frees the door from the chain that operates it. then close and open the door manually to prove the track is ok. then close the door and reengage the tripped mechanism. now press the button on the remote to retry. BTW... most doors will reset the catch mechanism automatically. just press the button and let her go.
Dec 21, 2014 | Building Materials
Product Lift Master Professional Line 1/2 HP Security + Model # 1265LM Door goes down intermittently. Door will go down approx. 8 - 10 inches, stop and then retract. Remote in hand, I press the...
Check alignment of the obstruction sensors .... they shoot a light beam across the doorway about 6 inches above the floor. One is mounted on each side of the door track near the floor.
Aug 29, 2017 | liftmaster Chamberlain Garage Door Opener...
I have two craftsman door openers. They work great with pushbutton on wall, open and close ok. The door opens fine with remotes ( one handheld other homelink in car ) but will not close with remote. It...
If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the lights on the sensors are both on and not flickering. Tweak them if necessary. If you cannot get both lights to come on you have bad sensors or the wiring to them.
Dec 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener and recently it has started to open on it's own but only opens half way and stops.This has happened a few times so I currently have it unpluged..any ideas
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Dec 09, 2010 | Craftsman 34 Hp Garage Door Opener Chain...
I have a Liftmaster garage door opener & remote. The remote began to work only intermittently. I replaced the battery (I didn't reprogram remote when battery was changed & remote worked for a...
COULD BE A BAD REMOTE, I WOULD TRY ANOTHER ONE FIRST.
COULD BE A FREEZER ETC. PUTTING OUT INTERFERENCE.
OR
Nov 10, 2010 | liftmaster Chamberlain Garage Door Opener...
Remote will open the garage door, but will not close it. It will move the door a few inches, and then return to the fully open spot. the control inside the garage works fine, except that recently you...
This indicates that the safety sensors are mis aligned. You can re align them by hand. There should be an led light on each sensor and each should be on, not flickering or off, no matter the color. Also check the surface they are mounted to for stability. For instance if they are mounted to the track and the track moves as the door cycles then you will have issues. This should solve your problem. Thanks BB
Aug 31, 2010 | Chamberlain 3Button Remote Control Model...
2005 dodge grand caravan sliding door problems
could be a partially broken wire in the wiring harness that runs in the door track. the wires are inside what looks like a plastic chain that allows it to move with the door and have seen them partially break not allowing power to flow the whole time
Dec 24, 2008 | 2005 Dodge Caravan
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
96 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
