Question about Health & Beauty
I have a phillips 4203.000.5872.1 beard and hair trimmer. The part trimmer K/G has just broken have had kit foe aprox 2 years is there any chance I can buy another part?. Thanking you. Ray Heath
Part K/G has broken
SOURCE: Battery Replacement for Remington PG-300 Beard Trimmer
Hi
The manual will give you info on the battery that is inside the trimmer.If you can get to the battery then buy same TYPE or similar to the original---VOLTAGE/CURRENT RATING/CHARGING etc and size, connection
Hope this helps
Jay
Posted on Nov 17, 2007
  • 61 Answers
SOURCE: I just bought a wahl detailer trimmer and when I trim my beard,
Your problem is in your blade adjustment,nothing is wrong with the clipper,trust me i've adjusted thousands, set teeth so that hair can easily be feed through when clipper is on,perfect solution,wish i could draw you a picture.
Posted on Jan 26, 2009
SOURCE: Trimmer malfunction
I had same problem, at first I could not find out how to seperate the small silver cover with the on/off switch from the rest. After removing the 3 torx screws, 1 at the power entrance, and 2 under the shaver blade. You can remove the black cover. I also removed 2 more torx screws to separate the battery, from the rest, (don't know if thats really necessary). The silver covers are 'clicked' into eachother. When lifted the part where the battery part was screwed into, the silver parts became partly seperated, then you can pull the part apart.
I cleaned/washed the trimmer part with wd40 contact spray.
Assembled the parts, and made sure that the little plastic nodge was came into the trimmer.
Cleaned it all (removed leaking wd 40) and works fine again.
Hopefully this is helpfull to anyone.
Goodluck,
Adrian
Posted on Apr 02, 2009
SOURCE: Remington HC600 hair clipper stopped clipping
To all of you: adjusting the screws won't help, unless you screwed something up yourself, of course LOL The same problem bothered me a few years, and an hour ago I found out it could easily be a single hair stuck between the blades, thus separating them a bit. Get rid of it and the trimmer will probably work again. It can even get out spontaneously, which happened to me and kept me wondering what was going on.
P.S. DON'T lubricate unless you are required to (check your manual) The model I have (HC210c) does't need lubrication, I guess yours is similar to it. And remember that NOT every oily substance is a machine lubricant.
Posted on Jan 12, 2010
SOURCE: conair beard trimmer: took screw out and can't
After removing the screw you must place your thumb on the battery cover (just below the screw where the 5 raised lines are) and slide the cover downward. The battery in this unit is soldered in. You may have to take it to a repair center to get the battery changed. The battery is a D-Sc type 1600mAh 1.2V. Good luck finding one. I thought the battery in my trimmer was bad after it sat idle for about 8 years. Turns out a little light sewing machine oil on the cutter head made it spring back to life.
Posted on Jan 15, 2010
What is the best beard trimmer for styling and sensitive skin?
Yes, you are right! Now a days most of the people are using electric shaver because of its advantages like:
  1. It gives a fast shave.
  2. It is cheaper than manual shaving kits
  3. It gives a smooth shave and also there is no chance to get cut or skin irritation
If you are looking for beard trimmer than i will let know that trimmers are used to cleaning up the edges. I would recommend you to use clippers rather than using trimmers because clippers are used for doing the bulk of a haircut.
Aug 16, 2014 | Panasonic ES 8077S Electric Shaver
I overcharged my babyliss grooming kit now it won't work
You will have to get new batteries. In Greece, there are specialist battery shops that supply or charge batteries for every possible use. One of these shops replaced my batteries for 8 euros and now my hair trimmer is as good as new again. The trimmer appears to take two common AA sized rechargeable batteries, so you should be able to change the batteries yourself.
Jul 01, 2014 | BaByliss 7053U Beard Trimmer
How to disassemble Philips QG3080 Beard Trimmer
dimitris, use brush to clean hair and don't open the machine.
Nov 09, 2013 | Philips QG3080 Beard Trimmer
Need G270 beard comb replacement
Take a comb and find the level of the teeth on the comb for the hair length you like. Then use scissors and cut across the top of the comb with your other hand. Mens Beard Care Beard Grooming Products Well Groomed Wizard
Feb 10, 2013 | Norelco G270 Beard Trimmer
On a Wahl Beard Trimmer 9876-536 -- what's the button on the side of the trimmer for?
The button info requested is almost 2 years old, but on my trimmer the button to the left of the power swt on the side is to lock the trimmer blade in the front or rear position. It is kinda weak and you can still move the blade if you push it. (I do seem to have the same one shown in the picture here.)
Later!
The Shadow
Nov 17, 2010 | Wahl 9876-500 Beard Trimmer
This is a very good shaving machine and i want another one
You can get these wahl trimmers from Nose Hair Trimmer, that can be used for removing unwanted hairs from nose, ears and eyebrows.
This place would provide you most attractive deals on these branded trimmers with free shipping service.
Apart from wahl trimmer, you can also get recommendations for various other branded trimmers that are hygienic, comfortable and safe to use.
lowcost2.ru_2015.05.08-12.19.02_984580_electric_shaver_nose_ear_face_hair_removal_trimmer_clipper_dlya_nosa_y_ushey_y_brovey3-lmanv4snjocb41esrne4nwpm-3-2.jpg
Dec 03, 2009 | Wahl Vision 180 Beard Trimmer
Health & Beauty Logo
27 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
