Question about Radio Communications
No Pleomax DAS-MF210 bluetooth headset manual
No English manual available
3 Suggested Answers
vanherringto
  • 1738 Answers
SOURCE: samsung bluetooth headset manual AATH200HBE
The AATH200HBE is just a charging cradle.
Do you mean the actual headset that sits in the cradle?
If so, it is probably a WEP200?
The user manual is at http://www.alternativewireless.com/samsung/Samsung-WEP200G-quickstart.pdf
Posted on Feb 04, 2010
award462
  • 395 Answers
SOURCE: i needs the manuals for n136 bluetooth wireless headset
try this:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Posted on Jun 03, 2010
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
I bought LG 730 Bluetooth Headset, unfortunately the language has been changed. Let me know how can I change to English
Ion know if I'm to late.....but Ive only had the headset for 2 weeks I somehow changed the language on my headset......I did try to live with it honestly......i just started trying combinations Lmbo.......
ANYWAY I HELD DOWN THE VOLUME UP AND DOWN BUTTON AT THE SAME TIME AND THEN PRESSED THE CALL BUTTON........
SHE THEN SAID ENGLISH PROMPT AND THAT WAS IT......
Apr 12, 2015 | LG hbs-730 Tone Stereo Bluetooth Headset
No English instructions. how can I get them as required.
You can download the English PDF Manual for your Samsung WEP460 Bluetooth Headset at:
http://downloadcenter.samsung.com/content/UM/200906/20090609220534656/WEP460_UserGuide_eng.pdf
Aug 30, 2013 | Samsung WEP460 Bluetooth Headset
I need the english manual for the fonegear mini Blu headset
try here. bought mine used and they changed the password. now to figure out how to change that. hope this helps. 3's
Grampa
http://www.manualslib.com/manual/251101/Fonegear-976.html#manual
Feb 19, 2013 | foneGEAR (00976) Wireless Headset
My plantronics Bluetooth will not go into pairing mode no matter what I do. I held down the call button and it does work. Are there any other alternatives?
When you hold down the call button do you get a red then blue flashing light? This is pairing mode. (also the only way to get this headset into pairing mode) Make sure the phone is close to the Bluetooth headset. For most phones pairing a headset is done by
  1. Settings/Tools > connections > Bluetooth > On (your phone manual will have all the specifics but this is usually the buttons)
  2. Turn your headset on (on/on switch) and wait till the indicator flashes red then blue.
  3. Set your phone to "discover" or "add a device" which steps are usually - setup > connect > Bluetooth.
  4. Once available headsets are available select your headset. If it asks for a code the generic code is 0000
  5. A successful pair is indicated by a blue light and also a confirmation on your phone.
Regards, Tony
Apr 20, 2011 | Plantronics Explorer 240 Bluetooth Headset
I have a new phone and cannot find my manual to load my explorer 320 blue tooth
You can find free Plantronics manuals on InstructionSheets.com.
Plantronics manuals and plantronics instructions are available.
Here is a link to the page where you can view the Plantronics Explorer 220 Bluetooth Headset Manual.
Dec 12, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I need to sync my phone to Nokia CE0560 bluetooth headset - help?
ich habe problem mit meine headset EC 0560 nokia
das kann nicht kontakt klang mit meine bluetooth pc ich möchte wissen was kann ich machen
Mar 21, 2010 | Nokia Bluetooth Headset Headset
Dont have instructions in english
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP01&searchWord=wep460&searchInputBox=wep460/
go to this site....about halfway down there is a link to the manual....hope this helps
Jan 27, 2010 | Samsung WEP460 Bluetooth Headset
Radio Communications Logo
197 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
