Question about Midland 75-785 Handheld CB Radio
I was recently given a midland handheld transceiver 75-785, turns on fine but, its brand new so in pretty sure everything works on it, but over these last couple days of tryig to fine tune it, not one channel/frequency has been recepted but my cellular telephone can pick them up
    Genius:
  • Midland Master
  • 1,795 Answers
Sounds like you fine tuned it to much . Now take it to a tech and get it done right.
Posted on Nov 29, 2014
5 Suggested Answers
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
SOURCE: CHANGING FROM FREQUENCY TO CHANNEL MIDLAND 75-822
Some models of the 75-822 do not offer this as a feature. Instructions for it are not included in the manual. I recently encountered a refurbished model packed with a manual such as this. Pressing and holding the "F" button toggles between Channel number and Frequency number display.
Posted on Mar 25, 2008
ginko
  • 19396 Answers
SOURCE: radio frequecies
I will have a look around and post back what I find in the next 24 hours, if you can send any link you may have, that will help.
Try also posting a request on The CB Radio Talk Forum , it is the biggest forum on cb radio.
Posted on Apr 22, 2008
  • 40 Answers
SOURCE: wont change channels...stuck on channel 8
on this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
Posted on May 16, 2009
One of my midland GXT635 won't send or receive from my other one.
Yikes- Sounds like it's time for factory servicing! Hopefully, they still support that model. If not you'll probably have to buy a new one.
Oct 01, 2014 | Midland Radio Communications
Midland 75-785 handheld cb gets hot to the touch when used
check the interior and find out where the hot spot is then replace it.
Apr 21, 2014 | Midland 75-785 Handheld CB Radio
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
I was recently given a TL-98Q Juki. I have it set up on a long arm quilting machine. I have put two sheets with cotton batting between on the machine. Everything is set up. I started the machine and...
Be sure you have installed a brand new needle. If it still does not pick up the bobbin thread, the machine may be out of time.
If the presser foot does not set firmly on the fabric, then that is what you want for free motion quilting. However, if you mean the presser foot is sloppy (wobbly), then the attachment may be loose or the presser foot is worn.
Jun 21, 2017 | Juki TL-98Q
I have a Midland 75-785 hand held, It was working fine then I went to use it and the squelch control is not working ( I get lots of static) radio still works. Sends and receives, but when I turn the...
what time of day are we talking here? usually skip is so heavy from 0800 until 1600 that no radio has a chance of transmitting or receiving.If you turn the squelch the other way what does it do?
Jun 22, 2011 | Midland 75-785 Handheld CB Radio
Nikon F3's light meter always underexposed
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Mar 06, 2010 | Nikon F3/T 35mm SLR Camera
I recently purchaced 2 Midland CB radios and headsets to go on two motorcycles. When I use them I get excessive feedback. It appears that the metal motorcycle handlebars interfere with the rubber antenna....
The problem is with the headsets, not the motorcycle. If the headsets are generic they may not have the proper mic connections. How do the radios work without the headsets?
Jul 11, 2008 | Midland 75-822 40-Channels Handheld CB...
Midland 75-785
Given the fact that when you key up the mic you should not hear any thing because the receiver section is "turned off" (no antenna and the speaker is muted). This would seem to indicate that the switch the headset controls which allow the change over from RX to Tx is bad or that the circuit in the CB unit which the head set plugs into is having a problem. Do you hear the same flutter without the headset? Try to get another headset or test one out just to see if the problem is eliminated by using a known good headset.
Aug 16, 2007 | Midland 75-785 Handheld CB Radio
Midland 75-785 Handheld CB Radio Logo
100 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
