Question about Garden
Replace motion drive belt garden tractor craftman 917273080
Motion drive belt 140218 how to install around engine pulley past the clutch
  • 837 Answers
On what make and model riding mower ..
Posted on Jan 19, 2009
    President:
  • 1,952 Answers
Www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm246_hwen1998_5321635-78.pdf -
DOWNLOAD THIS SITE
Posted on Jan 26, 2009
    Genius:
  • 1,239 Answers
Hi
This may help. If you want to make a speed reducer here is the information from MTD. With a speed of 2000 RPM to a 8 tooth sprocket, chain drive to 15 tooth on the same shaft as the 15 you have an 8 tooth with a chain to 16 tooth which is the output drive of 540 RPM. This is something that can be fabricated as pictured with bearing supports. You would make this for the rear PTO with a straight shaft to this box.
Why does the motor on my craftman riding mover stall when I let out clutch/brake?
Drive belt conditions? Wrong belt installation. Mower assembly will not turn by hand, so there are bearing and engine load problems? Clutch doesn't like the brake to be on?
Owner's manual trouble shooting? no manual
try manualslib.com
Mar 28, 2015 | Garden
Fix a motion drive belt squeals on a Craftsman 24 hp 42 in. Deck Lawn Tractor - CA Model
If I understand the issue correctly, the belt that drives the machine's transmission squeals. When does it squeal? When engaging the clutch? When in motion?
Typically it's the condition of the belt. It's likely slipping due to stretch, wear or from an oil leak causing it to slip, or simply due to a loose idler pulley, worn idler pulley bearing, broken spring. Look for all that stuff. Look at the drive belt and inspect for wear, cracks, fraying, missing rubber, etc. Replace it if any of those conditions are found.
Jul 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Installation of motor drive belt on cub cadet tractor
This one's a PITA. That said, I had to remove the PTO clutch and pulley, the seat, the brake and transmission pedals, and finally the sheet metal that constitutes the fenders and foot plates.
Belt is put over the fan above the transmission and onto the pulley there, then run along bottom of main frame towards the front until it reaches the engine drive shaft.
The belt goes onto a pulley on the engine drive shaft (above the PTO clutch and pulley, which have to come off). I couldn't slide the drive pulley down the shaft, so pulled the 4 engine mounting bolts and move the engine around slightly to allow putting the new belt on between the pulley and it's surrounding sheet metal. Once the belt was on, and before any other steps, I realigned the engine mounting holes and replace the bolts.
The belt is then run around the pulleys under the middle section of the tractor. Leave the spring loaded idler pulley for last. you might need to loosen (not remove) the bolt that goes through the idler pulley in order to get the belt on. The biggest fight is pulling the spring loaded pulley over so that you can put the belt onto it.
Once the belt is fully routed over all pulleys. Reinstall everything that you had to remove - and you should be good-to-go.
ONE LAST COMMENT: Many shops sell belts that DON'T have Kevlar. Make sure you but the one WITH Kevlar. The others rarely last one season.
Aug 31, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Change Drive Belt
I just did this. You may need a second set of hands.... Remove the mower deck & back plate. Depress the clutch (this shortens the distance between the pullies.) Pull the belt slack toward rear of the tractor. Remove belt upwards from the transaxle pulley by deflecting belt keepers. Pull belt toward front of the tractor and remove downwards from around the engine pulley. Install the new belt by reversing the procedure. NOTE- there's a diagram of the procedure on page 24 of the owners manual (which I downloaded when I couldn't find my original)
May 20, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Steps needed to change transaxle belt
lift the front of the tractor up at least 3 feet and lower the mow deck to give you clearance. push the clutch pedal and lock it down to release belt tension. remove the mower belt from the engine pulley only. remove the trans belt from the idlers about midway back then from the trans pulley & finally from the engine pulley. put the new belt around the engine shaft above the mower drive pulley but not on the drive pulley then around the trans pulley. now you can put it on the drive pulley and finally on the idlers. make sure you have it under all the various keepers or the belt will shred in like 10 minutes. release the clutch pedal & check the belt again to ensure it is in the correct place. replace the mower drive belt & ensure that didn't come off other pulleys in the process. lower the front of the tractor and test
Oct 14, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Cahnging drive belt on mower
dont understand your question ... get the belt ... it was designed to fit ... there are probably at least three pulleys. put the belt around the motor pulley and the trans pulley then figure out how the clutch or tensioner pulley interact with it.
May 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch vibration and jerking at slow speeds.
Check the drive belt. It probably has chunks missing or at least has flat spots (narrow spots) that cause the belt to jump every time it goes around a pulley. That will set up a heck of a vibration. Also check the pulleys for free movement. The drive belt is above the blade drive belt....
Jul 27, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
FS5500 24hp craftman electric clutch doesn't turn.
assuming the belt is on the pulley, of course. set the parking brake, turn the key to "on" [don't start it], and pull the PTO switch, you should hear the clutch click. if not, check the plug-in connector for the clutch to make sure it's connected firmly. yes? turn the key off, remove the belt from the clutch pulley and try to turn the pulley by hand. it should turn with a slightly stiff resistance, if not, clutch could be bad or need adjustment - if none of the above, replace the PTO switch
Jul 06, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
649 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
