Question about Hotpoint WMA54 Front Load Washer
Bra wire has between drums
A bra wire has got in between the inner and outer drums. Is there a way to get into the drum without removing the whole assembly fom the machine? It looks like there are catches to remove the front of the drum, but no obvious way to access them. Any tips would be appreciated.
  • 1 more comment
  • Bruce Hall Jun 25, 2007
    Actually, I took the plunge and succeeded.
    For anyone else with the problem:
    The minimum part removal to access the drum are:
    - Door seal (remove clip top left inside door, then remove locking wire and remove seal from fornt panel)
    - Lid (3 screws on back)
    - Control Panel (4 screws around detergent drawer) and it unclips on the right hand side
    - Front panel (3 screws along top and another 3 along botom)
    - Door lock (2 screws) allows panel to be moved out of the way
    Mow you should have a clear view of the black clips holding the drum fac onto the drum cylinder.
    Pop those off (watch the hidden clip bottom dead centre behind the element connecter), and the front comes away nice and easy, bottom first to get the element out.
    You should now ave easy access to anything between the drums.
    Put back in reverse order.
  • shonab Jul 01, 2008
    I think there is a coin stuck in my drum, will i do the same procedure to get it out
  • Anonymous Mar 25, 2014
    how can i remove it as it is stuck in the drum
  • 35 Answers
You will need to call in an on site tech.but from my exp.the tub assembly would need to be replaced if you want to solve this problem.
Posted on Jun 25, 2007
While spinning, it made a loud noise but finished washing the load while continuing to make the noise especially while spinning fast.
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
Sep 14, 2015 | Miele Touchtronic W1213 Front Load Washer
Loud squealing sound during spin cycle
Possibly a foreign article stuck inside the drum. When the machine goes onto spin this can rub against the outer drum causing such a sound.
This is commonly the underwire from a bra that has worked loose and lodged in one of the holes inside the inner drum. Have a careful feel round the whole inner surface of the drum to see if you can detect anything protruding. If you find a wire, grip it with a good pair of pliers and try to pull it out, remembering the shape that it probably has so it will need to be coaxed out accordingly. Anything protruding through the holes doesn't belong there!
I have removed three of these from our washing machine!
Mar 09, 2010 | Maytag MAV7700 Top Load Washer
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
How do i reemove a bra wire caught in between the outer drum and inner drum of a hoover nextra 6 washing machine
Hi
Disconnect the machine from the power source and also disconnect the inlet hoses.
First start by opening the top hatch. You can do this by first opening the lid. there are 2 screws under plastic caps in the corners, under the lit. Open the screws.
See if you can lift the top hatch back. If not, you need to open the screws, or sometimes no. 7 bolts, in the back of the machine. These join the top hatch (plastic part) to the machine body (metal part).
When you raise the top hatch, there will be a power connection with earth wire, and a presure hose which connect to the bottom of the control panel. You can disconnect these. Take note, as you need to put them back on later.
Once you remove the top section you have clear access to the top of the drum. There is a plastic rim on top of the drum which you need to remove. Sometimes they are screwed on, and sometimes they clip into place. The old hoovers were clip on plastic. The newer hoovers are more like Simpson and have screws.
Once you remove that, look down in between the inner and outer durm and see if you can see the bra wire. If you can get to it with a long object it will be alot easier, than having to remove the inner drum. If the bra wire is free and just sitting on the base, just tilt machine to its side and with the help of a few people turn it upside down.
Removing the inner drum is a pain, and I do not suggest you do that yourself, unless you have the right tools.
However I can help you with it if you can not get to the wire. Let me know.
Regards
Ash
Nov 20, 2009 | Washing Machines
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
How do you remove underwire lodged between drum and outer case
hi to remove bra wire from between drums ? you might try this 1st ? if you diconnect water supply hoses and unplug power supply then remove rear panel from machine you will have access to the large rubber drain hose from outer drum down to discharge pump ? ok hose is held by spring wire clips both ends remove clips then hose you may find bra wire either in hose or close to drum drain if you need ? feel inside drom via drain hole ? or probe with a piece of coat hang wire ? you may even find the mysterious missing sock/ thong / etc when you disconnect the hose too?? any debri has to lay in bottom of outer drum and so a little patience will locate them using this method instead of removing the main front door sealto drum for access to same area also with rear panel off you can check belt tension ? hope this helps/inspires you ? best wishes from uk
Feb 26, 2009 | Hotpoint First Edition FEW12 Front Load...
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
HOMEMAKER WASHING MACHINE MODEL : HMXQB70-722 HOW CAN YOU GET BRA WIRE OUT WHICH HAVE GOT BETWEEN THE INNER AND OUTER DRUMS.
The only way without disassembling the machine would be trough wide rubber hose which connects filter housing and drum. If you're lucky you'd be able to reach it wit your hand or some tool. Still that would require a lot of work, luck and wouldn't come out without expenses for new rubber hose since they are usually glued to drum.
Apr 27, 2008 | Washing Machines
Bosch Classixx 1200 Express - metal got under the drum
This video will show you how to get into the drum through the heating element and remove the bra wire on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Washing Machines
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Hotpoint WMA54 Front Load Washer Logo
371 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
