Question about Husqvarna Chain Saw Models 371, 372xp
Carb adjustment screws on husqvarna chainsaw
Label the adjustment screws
  • 41 Answers
SOURCE: I have a husqvarna 340 chainsaw and it will not
Turn the screw labled T in a little. This will raise the idle setting. Heres a link to the manual. Look on page 29 of the .pdf
http://www.northerntool.com/downloads/manuals/195946.pdf
Posted on Aug 02, 2009
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Posted on Sep 11, 2009
  • 15 Answers
SOURCE: cannot adjust carburator on husqvarna chainsaw 435
the screws are on the side of the carb very small heads flat screw driver is needed as they have a cover on them it has to fit inside the cover H (high) and L (low) tighten them all the way in tight but not forcing them turn anti clockwize 1 1/4 turns try to start the saw pull the trigger and adjust the H (high) till it runs smooth then  let it idle then pull the trigger again saw should rev without loss of revs if it does turn the L (low) small amount either way till it does  hope this helps
Posted on Oct 19, 2009
nova2nv
  • 197 Answers
SOURCE: I have a husqvarna 55. I put in a new carb, coil,
If you are still having problems I would check or replace white grommet inserted into cylinder and connected to manifold,they have issues with breaking or blowing out.This model also has problems with the black intake boot not sealing around cylinder and manifold,an easy check by spraying a LITTLE carb cleaner around problem area.
Posted on Nov 18, 2009
  • 4088 Answers
SOURCE: carburetor tool
Unless you are skilled enough to make your own, you are stuck taking the saw to a servicing dealer as they are the only ones allowed to possess the necessary 'D' head screwdriver. Give thanks to the EPA for mandating the prevention of mal-adjustment pollution.
Posted on Jul 07, 2010
Which screw is the high and low when adjusting carb
if you have three screws then the one that is by itself will be the idle (usually labeled L) then you will have 2 side by side. the screw closest to the cylinder is the low and the one farthest from the cylinder is high. if you only have 2 screws then there isn't an adjustment for high
Sep 25, 2014 | Garden
Husqvarna problems
sounds like your air fuel intake needs adjusting..You can start by running the adjustment screws all the way in then back them out 3 full turns then go from there a half turn each time until it idles..The screws are located on the carb...
Aug 13, 2014 | Husqvarna Garden
How do i adjust the metering arm in the carb of a model 141 husqvarna chain saw
All adjustments made to the fuel are screw adjusted, three screws are low ideal, high ideal, throttle stop. A flat he'd screw driver should do.
Sep 04, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Vauxhall omega 3.2 how to turn up the idle speed
there should be a screw for the adjustment. Not sure why you would need to adjust the idle unless you have recently rebuilt the carb. usually there are 2 or 3 screws for adjustment 1 labeled L for low H for High and the third would be the idle
Feb 19, 2013 | Garden
What tool is required to adjust the carb. on a 142e husquvarna chainsaw?
http://www.ehow.com/how_7241334_adjust-husqvarna-carburetor.html
Nov 19, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to adjust carberator
Some Husqvarna carbs require a special screwdriver to adjust them, some just use a mall flat head tuning screwriver.
Screw both H and L screws in. Then turn them out anticlockwise the following amounts to return them to standard.
H 3/4of a turn L1 full turn (Chainsaws)
Some equipment like blowers and strimmers are:-
H 2 1/4 turns out L 2 1/4 turns out
Nov 03, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What do you mean by LA in the chainsaw?
Locate the adjustment screws near the carburetor labeled with an "H," an "L," and an "LA." The "H" screw adjusts the high speed fuel-air mixture; the "L" screw adjusts the low speed fuel-air mixture; and the "LA" screw adjusts the idle speed.
Jan 14, 2012 | Stihl Saws
What tool is needed to adjust H & L on a Husqvarna 142 chainsaw ?
This machine has a carb with splined adjuster screws, the toll to adjust them is part no. 530035560, it is readily available however i heard that the dealers in the US are very reluctant to sell it to end useres, so you may have to buy off the web.
Sep 17, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
We just changed the printhead, but now it is not printing correctly. Barely any ink shows up on the label. We tried adjusting the screws like the manual says but it did not work
bakery28: Loosen the top screws and then adjusts the position of the head with the front screws. This is a bit complicated and requires patience. Finally, tighten the top screws.
Roberto Martinez
padrino99@prodigy.net.mx
Aug 23, 2011 | Datamax DMX-I-4208 Label Printer
Husqvarna Chain Saw Models 371, 372xp Logo
81 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
