Ruud ugfd furnace flashing code 5 and then 7 repeatedly. wont stay running
  • Perry Putnam
    Perry Putnam May 11, 2010
    Somewhere on the furnace, usually on one of the panels there is a chart or list that tells what the flash codes mean. Have you checked your filter?
4 Suggested Answers
SOURCE: Why Wont My Bryant Furnace Stay Running
You have a dirty flame sensor, it needs to be replaced
Posted on May 03, 2009
heatman101
  • 43501 Answers
SOURCE: Trying to wire RUUD gas furnace. connection block
No problem have done this many times. R from the t-stat goes to R on the indoor unit. G goes to G Y goes to Y and C goes to C if you have a C or the t-stat the you are using. If there is no C there dont worry about it. It only need to be hookup if the t-stat uses power from the unit to run. Many t-stats today use battery power and do not need the C wire hooked up. Now R and C from the outdoor unit. R goes to the Y on the indoor unit and C goes to C on the indoor unit. That means that you may have two wires under the Y terminal and sometimes under the C terminal on the indoor unit. If on the outdoor unit there is no designation of R and C dont worry, just hook one wire to each of the two wires there for your low voltage connection. It does not matter which one goes to which unless they are marked then it may matter.
This should get you up and running and see it really isn't that hard!! :-)
Posted on Nov 14, 2009
Testimonial: "Thank you very much! I have been searching the inernet for hours to find a manual or diagram. Got a response within 15 minutes of posting. "
Therinnaiguy
  • 1420 Answers
SOURCE: Ruud Silhouette II Gas Furnace, the furnace lights
Bad or dirty flame rod.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Jan 10, 2010
What is kicking off to make my furnace go through its cycle and then blow cold air and wont shut on my Ruud gas furnace
it could be flame sensor or high limit switch how long do burners run does the fan stay on while this occurs
Dec 15, 2016 | Ruud Heating & Cooling
My ruud achiever 90 plus furnace wont run. thermostat shows system on, seems ok but furnace itself wont run. system has power.I can hear the power come on when I depress the access panel switch and also...
See if you can locate the control board. There should be an automotive push in fuse on it. It should be a small amp fuse around 3-5 amps. Check it and change if needed. You should be able to see if it is blown or not just by looking if you don't have access to a multi-meter.
The control board is usually located in the blower compartment. Thank you.
Jul 10, 2011 | Ruud Heating & Cooling
Rheem furnace problem wont stay lit
You need to see what it does. Does it light at all? will the pilot stay on? If lights but wont let you release the knob then thermocouple is bad. I
If it is electric start then watch the series of events. enducer fan motor starts, element heats up, gas lights but shuts off after 1 second. 5 seconds 1 minute and so on. Also your computer board on the furnace will flash a code indicating a problem. count the flashes and read the panel on the furnace for help it should give a description of the the errors.
all depends on the age and type of unit. respond if you have more questions .
Feb 15, 2011 | Heating & Cooling
Furnace is 7 years old. Will not stay running for more than 5 min. Will start up again after shutting off and then run for another 5 min. Suggestions?
Check the air filter. Jump out thermostat to see if it stays running longer, if so replace thermostat. Make sure all return air ducts are clear of debris. If furnace has a Fan/Limit switch, make sure tabs are set at 100, 140 and 200. Sounds like something may be heating up and shutting unit off till it cools back down.
Jan 03, 2011 | Ruud Heating & Cooling
Ruud Silhouette II Fails to Ignite
sounds like you have bad flame sensor or the sensor is in a bad postition. To get eliminate the lockout turn the power off to the unit and back on again. Look at the circuit board light and see what the troubleshooting code is.
Jan 13, 2009 | Heating & Cooling
Ruud Achiever 90 Plus wont start
4 blinks is "pressure switch closed" there are 2 in the system according to the wiring diagram one for the vent system  and one for the drain system ... I just wiggled them and heard one "click" the fault light quit blinking and when I pushed the safety switch back in the furnace fired right up.  That being said is there a good website for learning how to maintain your own furnace?  I'll call a pro if I have to, but shoot I can fix a jet engine... this shouldn't be much worse.
Thanks  dan
Jan 19, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
592 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
