Question about Fujitsu Siemens Computers & Internet
Computer switches on, fan starts but doesn't boot up
Lights come on, fan starts and keeps running but doaes not beep and then boot up as normal.
sparky1500
  • 1066 Answers
SOURCE: Emachine Will not boot
different beeping patterns are codes which indicate what part of the hardware has failed (ram, video card, cpu, ect). the fan failure would not cause beeps, and would not cause the cpu to fail unless already in windows. if you could find out the manufacturer of your motherboard you could check with them about what the paticular pattern of beeps which you are getting mean.
Posted on May 17, 2008
SOURCE: tower shuts off after it beeps on start up
There is no way it's the video card because if it was, your bios wouldn't be showing up.
Try resetting your SEMOS by doing this, it'll put your bios at stock settings. To do this, unplug your computer then take out the battery on your motherboard for 10 mins, plug your computer back in. With computer on, re-insert battery.
You should also try removing any USB devices that may be causing your computer to re-boot.
Posted on Jul 20, 2009
  • 263 Answers
SOURCE: power and fan run light flicker in front does not boot up
Relace the psu it's a dodgy Bestec ..replace it with a winpower psu 400 watt , they are cheap but they work better.
Posted on Jul 29, 2009
  • 266 Answers
SOURCE: computer wont boot up
you need to refix the RAM sticks and restart your pc. IF the problem persists change the RAM slots and put RAM sticks one by one in different slots, then restart your pc it will work
Posted on Feb 15, 2010
  • 60 Answers
SOURCE: Dell Inspiron 546; 5 beeps
it is either a memory or graphics card problem. you can clean the pins on the memory cards and the graphics card with a pink erasure and reinsert them and see if it gets rid of the problem.
Posted on Mar 13, 2011
Alienware Area-51 Desktop PC No Video. Long Beep.
you my have a power problem,the beeping is a sign that your graphics card is not getting enough power ,check your power cord to your card .
have you upgrade any hardware in your pc.
try cleaning your fan they get loaded with dust or you may have to replace your fan.
hope this helps
Sep 21, 2012 | Alienware PC Systems Alienware Area-51®...
Memory upgrade on gx280 beeps on boot but doesn't start. memory beeps 1 234 5 6
When your computer emits beeps when you power on the computer, it's usually means that you have a memory issue. Try re-seating the memory modules and power on the computer. If you have more the one module, insert one at a time and power on the computer. The other issue is if that model supports 4 gig memory.
Aug 30, 2012 | Dell Computers & Internet
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
I'm having problems with my compaq sr5000 desktop.
Is there any message that appears when you turn the computer on? Does anything post to the monitor during the boot process? Normally if the Video Card goes bad and the monitor works you will get a No Signal message on the Monitor. So you are so sure the monitor works, huh?
Since you went inside the computer check and make sure you pushed the Video Card (where the monitor plugs into the back of the computer) into the slot all the way.
Maybe your Power Supply is not working. When you press the power button do the fans start running and you hear the disk drive spinning? Just because you see a light at the the power button or on the motherboard does not mean the Power Supply is working correctly. I just changed one that did that.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.You didn't by chance remove the Heat Sink and CPU while you were removing the fan did you? If you did, you probably need to apply a fresh coat of Thermal Past between the Heat Sink and CPU.
Apr 21, 2012 | Compaq Computers & Internet
Shortly after I turn my computer it turns off
How long is shortly? If it runs and brings up the Windows Desktop and you are allowed to work for 10 minutes or longer then it shuts down, most likely the laptop is overheating. One way to tell if it is overheating is to immediately try to turn it back on after it shuts off. If it will not boot back up, it's overheating. If you let it sit and cool off for a while, then try to boot it back up and it does it successfully, it's overheating.Causes of Overheating:1) Dust all inside the computer. Fans clogged with dust, dust around the vents.2) Fan not working3) The Thermal Past around the CPU has dried up or is too thin the keep the unit cool.When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 31, 2012 | Gateway Computers & Internet
How to repair start-up on my computer
How long is shortly? If it runs and brings up the Windows Desktop and you are allowed to work for 10 minutes or longer then it shuts down, most likely the laptop is overheating. One way to tell if it is overheating is to immediately try to turn it back on after it shuts off. If it will not boot back up, it's overheating. If you let it sit and cool off for a while, then try to boot it back up and it does it successfully, it's overheating.Causes of Overheating:1) Dust all inside the computer. Fans clogged with dust, dust around the vents.2) Fan not working 3) The Thermal Past around the CPU has dried up or is too thin the keep the unit cool.When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Mar 28, 2012 | Computers & Internet
Computer wont boot, the fans keep running
Does it come with any beep sound, because beep sound clarify the fault. Check it by the way.
The list is given below.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Compaq Presario S4040SE - (refurbished)...
My motherboard(ga-6cxc rev 2.0 motherboard) don't show any sign of booting but if i let some part lose it beeps(long) what should I do? even the keyboard don't light up(num lock...) and monitor...
Unplug all of your RAM, expansion cards and IDE/SATA devices. Leave only the processor and the CPU/heatsink plugged in, now try turning it on. If it boots, you should get a ram error, which is normal. If it doesn't boot, either the board, processor, or power supply is bad. Next, reinstall the RAM and start it up again. If it boots again, keep adding parts until you find the one that is causing the problem.
Hope this helps.
Sep 25, 2011 | Gigabyte Slot 1 GA-6CXC-1 Motherboard
I have a Compaq Presario SR2020NX. I press the power button and the fan comes on, the green light is bright , the cd drive blinks then stops as if the computer is starting but nothing happens. The fan...
Disconnect the drive and try to boot to the BIOS (usually with F1, F2 or Delete key). If that doesn't work, try removing all cards from the computer (except a video card if the video port is not on the motherboard). If you can boot this way, try inserting back any removed cards to see what hangs it. Do you hear any beeps when the computer is booting (beep codes)?
Sep 24, 2011 | HP Compaq Presario SR2020NX PC Desktop
Computers & Internet Logo
73 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
