Question about KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator
Ice in kitchenaid freezer
Ice in bottom of freezer?
4 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: water leaking/freezing in bottom of freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help
Posted on Jul 12, 2009
toolkits
  • 1099 Answers
SOURCE: We have a 3 door
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension. 2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only. 3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost. 4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad. 5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!! 6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator. 7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install. Follow these steps and this will solve your problem. Good luck in solving.....
Posted on Oct 31, 2010
heatman101
  • 43501 Answers
SOURCE: My kitchenaid superba is leaking
I think that you may be barking up the wrong tree there...
It is not your ice maker, but instead it is the defrost drain....
When your unit defrosts the coil the water does not run down the drain but instead it runs out onto the freezer floor...
To figure this out you will have to remove the food from the freezer then remove the shelving and the back of the freezer.... there is a drain back there that runs the water away from the coils...make sure it is not clogged or frozen...
Water Running in refrigerator from Freezer
heatman101
Posted on Jan 19, 2011
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
Discovered ice build up on bottom of freezer in side by side KitchenAid Superba. Figure it is a defrost drain clog.... How do clear the clog?
I have ice in the bottom of my freezer section also in an older one of these, but I have traced it down to some sort of leak in my ice maker line. It only occurs when the ice maker is making ice, and not when the ice tray is full. Mine also leaks through the front door seal and into the floor if I don't keep scraping out the ice from the bottom (to clear out the "reservoir" that holds the water till it turns to ice).
I came on this site looking for a way to locate the leak and get to it. You might try scraping out the ice and turning off the ice maker for a while and see if the ice no longer forms at the bottom. Then at least you have localized it a little!
Feb 09, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Model was bought 1/92. Ice cube maker not working although we hear a churning sound that seems to signal something's trying to work! What do you think? KitchenAid KBRP20EMSS Bottom Freezer Refrigerator
Those ice makers get stuck from frozen ice portions. Try feeling around to see if anything in the icemaker is frozen up or any foreign object. Please do this with fridge unplugged. If you can't find any frozen or other obstruction then use the hair dryer to defrost the ice maker. This is only a guess from past experiences. My kids once put pop cicle sticks in the ice maker wanting to make ice cube on a stick. Goodluck Google burdfrenzy
Nov 26, 2010 | KitchenAid KBRP20EMSS Bottom Freezer...
My freezer compartment is full of ice and frost on kitchenaid ktra22emss
if a no frost frig is frosted then the defrost system has failed . look at the heater / and defrost terminator . and the aditive defrost control as any one of these will cause the problem. . on some models the drain in the freezer is pluged and needs cleaning . this will cause ice build up on bottom of freezer .. ( clean drain with hot water & turkey baster ....hope this helps mm
Oct 09, 2010 | KitchenAid KTRA22EMSS Top Freezer...
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Will not dispense water or ice
Check for broken or frayed wires at the bottom of the freezer door.
There is a wire harness that is routed around the bottom of the freezer door right by the hinge.
After many opening/closings of the freezer door, these wires tend to break or fray and short or open.
Aug 22, 2008 | KitchenAid KSCS25FKSS Side by Side...
Kitchenaid superba ice freezes in the bin
The temperature of your freezer is probably set to low allowing the ice to melt a bit, then refreeze. Try setting your freezer temp a bit lower. That should fix it.
May 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Architect KBRA20EMSS Bottom Freezer Refrigerator Logo
37 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
