Question about Dryers
Have a kenmore 70 110 60702990 that just stopped working when the wife went to use today. Timer does not tick and will not start. Light inside works, door is shut and did the test with the 2 blue wires (nothing happened). Is the timers shot? Timer doesn't click when turned to a time either.
  • Dryers Master
  • 8,220 Answers
Look inside it and see like I did:
This video will give you an idea what to look fer:
Posted on Dec 31, 2012
exspert
  • 55 Answers
SOURCE: Dryer not turning on
ok " the timer has points that act like a switch , they get burt and will not work after a long time
replace time , it's just a plug in unit
Posted on Jan 21, 2008
jsrock516
  • 5911 Answers
SOURCE: My non-starting dryer
Make sure you perform all checks with the dryer UNPLUGGED.
Double check the thermal fuse just to be sure. It will be located on the air blower housing and should be a white plastic component with two wires connected to it. It should read a short if good. I could be mistaken, but I believe the drum light will still come on with the thermal fuse blown. If I led you astray in my write up, I do apologize. All dryers are not configured the same.
If the thermal fuse is good, pull the connector from the drive motor and inspect it. I have found where these connectors look like they are tight, but actually aren't, causing the connector and wires to burn. If the connector checks good, you have a couple of options. You could have a defective motor. Take a resistance check across the blue wire and violet wire on the motor. This should be your start winding. Resistance should be between 2.4 to 3.8 ohms. If it reads anything higher than 4 ohms, it's recommended that you replace it. If the motor is okay you may have a defective belt switch and/or centrifugal switch. I'm not sure how your dryer is configured. I will need the COMPLETE model number (located around the door opening) to be sure.
Before I can give you further advice about troubleshooting or replacing parts, I need to be sure of what you find. Please post back and let me know.
Posted on May 29, 2008
  • 1122 Answers
SOURCE: Kenmore 90 series Model # 66912691
most of the time if a dryer does nothing it is the door switch done bad or the mine fuse behind the back panel on the blower box,let me know more-mike
Posted on Mar 11, 2009
  • 686 Answers
SOURCE: Kitchen aid electric dryer won't start. The door
change your thermal fuse
Posted on Mar 12, 2009
shinn8
  • 85 Answers
SOURCE: Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Posted on May 27, 2009
Kenmore washer model 110 82781800 won't cylce, just hear timer ticking
If the motor is going thru cycles and the agitator doesn't move, than it means the drive link snapped. cheap repair. it was made to protect the motor and trans. Read the manual before doing this. it will show you how to do it easily. iv'e done mine around 4 times. my wife keeps jamming too many clothes into the thing.
good luck
Apr 10, 2014 | Kenmore Washing Machines
Have a kenmore dryer model 110.66912692. Wife was using it for multiple loads today and then it stopped working. You can hear the timer ticking, and the push to start button makes a click noise like it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 22, 2010 | Dryers
Kenmore dryer stopped working, still has power.
When the timer stops during the duration of the time set the timers cogged tooth gearing has stripped out. A new timer will be needed to get your dryer working again
Apr 07, 2010 | Dryers
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
Just stopped working???
sounds like you have either a bad switch or bad timer. is there any humming when the switch is pressed? if so you could have a bad motor
Mar 26, 2009 | Kenmore Dryers
Dryer wont start anymore
If the drum won't rotate, you may have a broken belt. I had a Kenmore and as I recall, you have to pull up the top section to see inside. Good luck.
Sep 14, 2008 | Dryers
Dryer stopped working
  • first step, turn your circuit breaker off then back on.
  •  it is common for 220v appliances to trip only one side of the dual breaker resulting in a non-working machine that still seems to have power.
  • another symptom of this would be running with no heat.
if this does not solve your problem, don't give up. there is a couple other things it could be (E.g. door switch). just let me know
Jul 01, 2008 | Kenmore Dryers
Dryers Logo
63 people viewed this question
Top Dryers Experts
