Question about Whirlpool Duet GHW9150P Front Load Washer
Duet whirlpool ghw9150pwo
My washer is not working, but the control locked light is on ,and nothing else will work i tried the cancel
  • grammyrosean Jan 18, 2009
    puh in the end of cycle button for a few seconds
  • Anonymous Jan 18, 2009
    thank you. i had the same problem and i just fixed it!!!!!
    President:
  • 1,294 Answers
Press & hold the button on right of panel 'end of cycle' for 3 seconds, the light will go off. Child lock. <It will come on again if you dont vote me nice!!>
Posted on Mar 26, 2009
Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model# GHW9150PWO the contol locked light stays on and nothing else will work.
Hi
To unlock control press the END OF CYCLE SIGNAL button for 10 seconds. Hope this helps...
Dan
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model # GHW9150PWO The control locked light stays on the other bottons will not work
Hi
Dan
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PWO Have F11 and DL errors. Have replaced the door lock 2 x and still have same error messages.
Well du is a door lock error but it can also mean an error with communication to the main control board or ccu. f11 is also a communication error in either the ccu or the mcu ( motor control board)......easiest thing to try is to unplug all your connections to the ccu and plug them back in and try it again.....sometimes a wire harness just may be loose....if that dosent work I would look at replacing the ccu ( central control unit )
Jul 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150PWO
You must press in the control lock for a few seconds to disengage it I believe. Try unplugging and replugging the the unit if that doesn't work.
Dec 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet model number GHW9100LW2-control lock button stuck on red, cant do anything else. Tried pushing the pause cancel button nothing......An ideas? Thanks!
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Sep 07, 2007 | LG WM2077CW Laundry XL Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
205 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
