Question about Roper Dryers
Will a 3 prong power cord for a range work on a dryer
  • Roper Master
  • 8,220 Answers
No because the receptacle is different. The dryer neutral is curved. a stove 's is flat blade x 3
Posted on Dec 31, 2012
watugot
  • 290 Answers
SOURCE: Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Posted on Oct 05, 2007
  • 262 Answers
SOURCE: 4 prong dryer cord to 3 prong dryer cord
YES NEUTRAL GOES IN THE MIDDLE L1 AND L2 WHICH ARE HOT GO TO THE LEFT AND TO THE RIGHT LIKE THE CORD IS LAID OUT
Posted on Dec 11, 2007
Master_Tech
  • 770 Answers
SOURCE: changing four prong dryer to three prong outlet
use the ground on the machine.....There are 3 wires on the terminal block if you notice there is a grounding strap off the center post this will act as your ground to the machine back in your panel box the center post leads to ground anyway the other 2 are hot leads (240vac) use the 3 post you will be fine. you will be grounded let me know if you have any problems
Posted on Feb 19, 2008
jsrock516
  • 5911 Answers
SOURCE: changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Posted on Nov 11, 2008
frcs68
  • 1605 Answers
SOURCE: How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Posted on Apr 23, 2009
What a 240 plug look like
A dryer cord is smaller than a range cord and it also has a curve in the ground prong so that their would not be a chance to use the 30 amp cord with the 50 amp range. Dryer cords come in 2 differing styles 3 prong and 4 prong. typical dryer cords look like this:
Feb 13, 2013 | KitchenAid Dryers
Spectra profile performance jb960k0d1cc has power but neither oven and stove work
what type of power cord does your range have? is it a three prong cord or a four pronge cord. If it is a four pronge cord you must make sure that the ground wire is attached correctly on the back of the range. You can refere to your owners manual that came with the range on how to hook up the range cord.
Nov 14, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The dryer cord does not match my plug. is that cord required or can I buy another dryer cord and use that instead?
cord for dryer should be 3 prong and center being L shape or a 4 prong dryer corder with an L shape either one is fine aslong as its a dryer cord ,,,, donot put range cords on dryers they use different amperages and could trip your breaker and cause electrical overheating of wiring....
Jan 28, 2011 | Kenmore Elite HE4 Electric Dryer
Need to change from hard wire to 3 prong power cord
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Jan 07, 2011 | GE Spectra JBP78 Electric Kitchen Range
I have a Heavy Duty Super capacity 5 cycle dryer 3 temp range. Dryer came with 4 prongs and my recepticle only has three. Can I replace three prong cord with a three prong cord and how do I do that?
Yes you can. The 4th prong is ground. Just make sure you have the device grounded in some way. So you have 2 hots...a neutral and a ground.
Jan 05, 2011 | Dryers
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
Feb 03, 2010 | Roper REX4634KQ Electric Dryer
I need to replace the dryer cord which one would be the correct cord
The correct cord can be found at most appliance or building supply stores. look at the receptacle for the dryer. If it is 3 prong or 4 prong, that is the determining factor for what cord you need, The Dryer is rated 30 amps, 220 volts, That is the rating of the cord. BUT the cords will be labelled in the packaging. there are two that are similar, Dryers and ranges . you want the one labelled Dryer.
Jan 16, 2010 | Danby DCD5505W Electric Dryer
I have a kenmore dryer model 11060212990, and the plug has three prongs, but the wall socket is a four prong. what do i need to do?
You will need to purchase a 4-prong power cord and convert the appliance to meet the needs of the wall receptacle. This is a requirement of the National Electric Code in homes that have the 4-prong receptacle. The following link explains how to convert your dryer cord from a 3-prong to a 4-prong:
These rules apply to the conversion of electric ranges, as well. Read through the link thoroughly and let me know if you have questions. If you require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Dryers
Dryers Logo
85 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
