Question about Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter
Lose wireless internet when printer is on.
Hi I have a new Compaq desktop with Vista Premium using a Belkin Wireless G Network adaptor working with BT Internet. Didn't have any problems until I bought an HP C3180 photosmart printer. When the printer is switched on the internet connection is lost. The only way to restore it is to Restart the computer. I've checked on HP website and it says drivers are installed correctly. I've downloaded the updates from Windows Vista to solve the initial printer problems. Printer works fine if you don't access the internet. Any suggestions gratefully received.
  • Jan Bastin Jun 25, 2007
    Didn't find the option to 'enable windows WZC'.
    Found option to turn off power to the wireless to save power, so turned that off without success.
    Found an option to 'Enable Radio'. no success.
    I had previously tried moving the Wireless USB connection and lost the internet. So moved the Printer USB connection from connectors at the back of the PC to ones at the front.
    Hurrah
    President:
  • 2,961 Answers
The only thing that connects the printer to the internet fault is the fact that the printer and your belkin are both usb connected. If you are using a laptop then it could be a usb power problem and the motherboard is disconnecting the belkin adapter for some reason, the only one i can think of is a power problem. The same can apply to a desktop pc if there is a usb problem Firsly i assume you are using the belkin software to connect the usb adapter to the router, so on your taskbar on the right there is normally the little aerial type icon for the belkin adapter and a little pc screen showing the connection also, if you right click on one of theses icons you should get a line reading 'enable windows WZC', if you do get the option enable it and try using the windows connection software instead of the belkin as it may stop the disconnecting. Also ensure that when you installed the software to your printer your firewall and antivirus was dissabled as certain elements to the driver may not have been installed. Lasly, try using different usb ports if you have spare ones, with both the printer and the adapter as sometimes the chip on the board may be instructing the usb ports incorrectly as to which is required first, as windows asks for certain things eg input/output ports to be used first,in other words the IRQ (interupt request) may be causing the problem.
Posted on Jun 24, 2007
SOURCE:
I have a Belkin Wireless adaptor and a wireless router. The netgear adaptor I had before on my desktop got borken so I replaced with a Belkin adaptor. The new Belkin adaptor is not recognizing the wireless...
Hi, did you provide the network key/password when you setup the wireless conection on your computer? Is it detecting your wireless router (you should see your SSID or network name) when you click on your wireless icon (in the taskbar) and chose "show wireless connections". If you can acess to your router via it's configuration page(type the router's default IP address in your browser) you can go check the settings and change the key/passphrase if you dont remember it. If all of this is not working, you can also start from stratch. Reset the router to factory settings (check your manual) then reconfigure it the way you want, put the new infos in your wireless network connections properties and try again. let me know with more specific details if you still cant do it
Jun 08, 2009 | Belkin Wireless Desktop (F5D7000FR)...
Belkin Wireless G desktop card & BTHome Hub
hi..
it has been seen that due to some reason the wep key doesnot work...
u can try changing the key type to WPA instead of WEP...
go to the router page and change the security type to WPA instead of WEP..
1 more thing in vista you can use the windows utility only...how come is it possible that you are using the card utility as well..i suggest you to disable the card utility and just use the windows default utility..
vedhick.....let me know if u need steps to change the security type to WPA..
Jan 26, 2009 | Belkin 802.11g Wireless Desktop Network...
Getting Vista to use my wireless internet connection correctly
One question, is... do you need to enter a KEY or is this an open network?
I have found that with a new computer, you need to do the following to connect.
If this is an open network, then leave your router running, and just do a cold boot with your computer.
IE: Shut down, count to 10, and then re-start.
You may also need to connect (by network cable) to your router and make sure the wireless is turned on.
Most new rountes start with the wireless disabled.
Jan 01, 2009 | Microsoft Windows Vista Home Premium with...
Restored factory settings on pc & cant re -instal belkin adaptor
The Belkin site has very specific instructions for installing this adapter in a pc with Vista. These instructions are at: http://www.belkin.com/support/article/?lid=en&pid=F5D9050&aid=6112&scid=0
I would first unistall any Belkin Software that has already been installed, shut down the system completely and then restart. After you have fully restarted the system then follow the Belkin Site instructions EXACTLY. Any variation is apt to mean an unsuccessful install. Good Luck and have patience.
Nov 14, 2008 | Belkin 802.11g Wireless Desktop Network...
When using the Belkin G router the network connection becomes lost and can not get on the internet. My computer has Vista on it and Belkin says that the router is compatible with the program.
This is possibly caused by your firewall or the wireless security (wpa/wep) on the router if you have set it up.
First of all, if you can connect to the internet via a cabled connection the problem is going to be with the way you've set the router up.
If you've setup wireless security on the router, have you also set it up for your wireless adaptor?.
I suggest you try to connect to the internet via cable to start with, if this works try to connect wirelessly with your firewall off.
If all else fails start from the beginning again.
May 15, 2008 | Belkin Computers & Internet
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your [email protected] and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link wireless router and Belkin Wireless G USB Network adapter
Set your wireless network as a preferred network and to automatically connect to it. Also set it at the top of the list so that it takes precedence. If you continue to get conflicts, change the channel of the router.
Mike
Oct 31, 2007 | Computers & Internet
Can not identify Belkin N1 Wireless USB Adaptor on PC
Hi, A couple of things: 1. Have you tried all the USB ports of your desktop PC (front and back)? 2. What is your desktop PC brand/model or at least the motherboard? and What OS please?; 3. If running Windows in the desktop PC, can you please check in your Device Manager if your USB are 2.0? 4. Are you using a USB hub or directly connected to the PC's USB port? Hope this be of some idea/help. Pls post back with your desktop brand/model/motherboard. Good luck and kind regards.
Sep 16, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin F5D8630 wont take my new log in details
check to see if all of the ssid's are all the same or if there is another wireless system interfering.
Sep 11, 2007 | Belkin (A3L85014BLS24)
Open Questions:
AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]AVG customer service phone +[-\@;-{+1'888;499^5520}]
Oct 17, 2019 | AVG Computers & Internet
NOTON customer service phone +[-\@;-{+1'8OO;8O3^1O69}] NuMbEr USA .Anita This NOTON USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 NOTON USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the NOTON USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, NOTON USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. NOTON USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact NOTON USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling NOTON USA Calling NOTON USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from NOTON USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with NOTON USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare NOTON USA's phone numbers against each other. Contacting NOTON USA in General While I8OO8O31O69 is NOTON USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach NOTON USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact NOTON USA.Anita
Oct 17, 2019 | Best Computers & Internet
Indian spammers seek ceasefire in Syria - having won battles with FIXYA *AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]*AVG customer service phone +[-\@;-{+1'888;499^5520}*]
Oct 17, 2019 | Computers & Internet
See all Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter Questions
Belkin F8T003 Bluetooth (F8T003V) Wireless Adapter Logo
163 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
