Question about LG RZ32LZ50 32 in. LCD Television
LG RZ 32LZ50 WHAT'S SOLVED THIS PROBLEM? THE INTICATOR LED IS BLINKING RED -GREEN IRREGULAR AND THE TV ITS NOT START ON
rylee_smith
  • 8619 Answers
SOURCE: RZ-42PY10X LG TV I HAVE A RED LINE DOWN THE RIGHT
Hi
Thanks for using FixYa. From what you have described it seems that you might have a backlight issue with this TV set. It could also be due to the inverter circuits for the backlights. The inverter is the power supply source for the backlights. There could also be a screen driver problem; if it is then you have to change the entire board. All this is only recommended if you have some kind of expertise for checking the internal circuitry of the TV as these units have high voltages running even when the set is switched off. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 12, 2010
Testimonial: "is there any chance i could get hold of the wiring diagram"
rey jr
  • 149 Answers
SOURCE: LG RZ 37LZ55 37 in HDTV LCD Screen Dead
hi there, the lights indicate that you have no video signal. do some test. ty
Posted on Jan 10, 2008
ButtFuzz
  • 463 Answers
SOURCE: LG 37LF65 LCD TV BLINKS 3 GREEN THEN 1 RED THEN TURNS OFF.
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
http://www.observations.biz/MANUALS/LG_LCDTV/42LF66.pdf
Posted on Mar 12, 2009
  • 5 Answers
SOURCE: red blinking light when tv is turned off
if this is a 37lg30 i have brand new spare parts. the tv was never used it was dropped and the screen was damaged so i just took out the parts out. i was originally looking for some one that had a problem with there tv but a good screen like you but its easier to ship out the boards.
Posted on Jun 06, 2009
SOURCE: LG RZ-37LZ55 LCD TV no piture or sound. Set popped prior to probl
just repaired mine same problem
available on ebay ( lg power supply repair kit £17.99 does the job well
Posted on Sep 21, 2009
I have a tv . LG 37 " when you turn on the LED changes from red to green but no signal . If I leave so the day is spent with LED green but no signal. When I turn off the LED blinking green and
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 21, 2016 | LG Televison & Video
Power up problems
It sounds like the power is pulsing - that would explain your speakers. Speakers wouldn't make that sound if they were getting power at a steady rate. Look for a bad capacitor. It's possible you have one or more capacitors that have gone bad. They charge to a certain point, then somehow complete a circut momentarily and discharge, giving a pulsing flow of electricity. You can look for visible signs (leaking capacitors, or capacitors that are leaning over), or you can just start testing them with a voltmeter. If you find a bad one, you'll have to get a replacement and solder it in place.
Aug 06, 2007 | LG RZ-20LA70 20 in. LCD Television
Have a LG 55ls5700 tv that doesn't turn on but the red standby comes on and when i press the power button it starts to blink
Does the screen quickly blink on and then off? Does the standby light slowly blink twice and then go out?If these are the symptoms then it is probably a bad led backlight strip.This was the fault with my lg 47ln540v led lcd tv.I have written this up in a previous post more comprehensively.Hope this helps..
Mar 19, 2015 | LG 55LS5700 - 55 LED LCD Smart HDTV,...
Sony CRT TV type:DRC-MF DR34M69, long time to ON, LED stand by blinking red and green, how to solved this problem? Thank You.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Feb 04, 2014 | Televison & Video
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
When I turn on the tv, green light blinks for a
Its your ballast. it has as short. i recommend changing the ballast. while you are inside the set, i would run a break point test on the power board to be safe but, im sure its the ballast.
Mar 09, 2009 | Televison & Video
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
LG RZ-20LA70 How do you....
I'm trying to plug in a RZ-20LA70 TV into a Sony DVP NS29 DVD player? Which wires (red, blue, green) go into the coaxial, audio L, audio R, video slots? Thanks, Simon
Jan 14, 2008 | LG RZ-20LA70 20 in. LCD Television
This is likely due to a failed power supply. Replacing the power supply board should solve the problem.
http://www.reviewcentre.com/reviews110919.html
Cr1spy
Jan 10, 2008 | LG RZ-37LZ55 37 in. HD-Ready LCD...
LG RZ32LZ50 32 in. LCD Television Logo
97 people viewed this question
Computer Repairing
Computer Repairing
