Theres nothing you can do its the game you can't actually fix the game so you will have to get a new one.Theres nothing you can do its the game you can't actually fix the game so you will have to get a new one.
You can't post conmments that contain an email address.
Go down the only path available to you and you'll meet White. Talk to him, then open the sealed door just left of the entrance with a Bomb. Go through it to find a red chest, which will yield the Venus Shield if you have the Venus Key.
Now you can set to the business of figuring out what the statue is for. It's a stepping stone just like those ice pillars in the Falls Basin. Push it all the way to the left, then all the way down, then all the way to the left. There will be another red chest just to the left of that; it contains the Blizzard spell.
Now leave the Tower altogether and come back through the entrance which you originally took to get to Aquaria. Go down the staircase to the room with the four coloured doors. Assuming you have the River Coin, the blue door can now be opened. Go through it and up the stairs.
In the next room, head south of where you entered and you'll see that you're now able to jump a gap. Do so and leave via the door in the northwest. Then take the first door you see and you'll find yourself in a whole new quadrant of the map.
On your way to Fireburg, the next town, you'll encounter three Battlefields. If you clear the second one, you'll win the Gemini Crest. You might want to postpone this for a bit, as you'll be getting a new ally shortly.
I have the same problem...im pretty sure its sumfin to do with when my system updated.... Blooding Frustrating ive been waiting 4 a rugby game since rugby 08
maybe it has to do with scratches deep scratches that won't come out sometimes it only takes 1 sometimes it takes 10 its all chance and a good way to find out is some disc fixer if it can't get it out its a bad scratch (and disc fixer never seems to run out i got $7 gamestop one years ago i still use)
A golden level sign is a badge of honor showing the player they have completed an in-game level to the highest completion standard. It is a graphic that sits above the level select graphic. To have the golden level complete sign hang over every game level, players must collect every available item and rescue every prisoner in the level during one play through. A good tip is to use the x-ray scan card to more easily find all the prisoners and collectibles.
All Boss Cards
The way to achieve a boss card is to destroy the boss the player is fighting as quickly as possible. If the player defeats the boss quickly, a onscreen message will pop up informing the player they succeeded in getting a boss card for that boss.
The best way to do this is to make sure the in-game character is equipped with lots of grenades and a special weapon. On the fourth boss, use the flame shot. Try to use the Metal Slug if applicable. Players can use the Metal Slug for the second, third and final bosses.
Unlock the Extra Dungeon Mission
During the fifth mission, collect the dungeon card. The card is located in level five, section three. In Metal Slug Advance, players can take different paths to the end of a level. To achieve the dungeon card, take the top path directly after the first playable screen of level five, section three. Then, take the top path again at the next opportunity to choose a path. This is a dead end. Kill any existing enemies at the dead end and pick up the dungeon card collectible. Head back towards the previous screen and finish the level. Once the player has completed the fifth mission and collected the dungeon card during play, exit to the mission select screen. In the upper left hand corner will be a selectable extra mission called "Dungeon."
http://www.cheatgenius.com/gameboy-advance-cheats/metal-slug-advance-cheats/you can also check the above link..if this helped please vote for me..good day to you
Once you beat the water fiend, go to Melmond and talk to the brown-color-haired person called Unne. He will decipher the Rosetta Stone. Then go to Lufenia and talk to a person in the southwest for the Chime. Now go to Yahnikurm Desert, then go to Mirage Tower. This will take you to the Flying Fortress, where Tiamat and the wind crystal are.
your game is not right downloaded because probably is a piece of the game but i think is not the full game so try to download it somewhere other website and try it again.I hope it helps
for some reason your xbox is taking a long time to connect to the Square Enix servers. I can only suggest you make sure to have your cache cleared for a smooth load. You may have to redownload the game.
I have the same problem. The Wii has a better lazer eye on it that can read through more scratches and gunk and smudges and stuff than a gamecube. The gamecubes lazer is alot weaker and more touchy and more likely not to play a scratched disc than a Wii would..
Patty and Selma make up the heads of a two headed dragon (real surprise there) that is reeking havoc on a village. First recruit some villagers with Marge's mob control. Now switch to Homerball and watch the dragon. It flies and pauses in between gaps in the bridges that make up part of the upper area. Blast across the bridge and into the dragon to knock it to the ground. Now switch to Marge and command the minions to attack. Repeat three times to defeat the dragon before it destroys too many homes.
The next area is a dungeon. The Moe's will continue to attack until you destroy the gray brick structure they are spawning from. The coffins house more potential mob members. Continue forward and grab Marge's police hat near the bridge. Go up the stairs to the left destroying Moe's and enemy spawn doors. At the top is a treasure chest and a lever that opens the large door below. Pass through the door and fight of Otto and his spawn point. Step on the buttons to enter the overhead camera dungeon crawler portion of the game.
Move up to the large closed off area with the Moes and destroy the wall. Defeat the Moes and grab the key. Move back around to the yellow wall and it will disappear. Enter the hole in front of the statue. At the next part of the dungeon turn left and go to the end of the hall. At the dead end is another giant key. Head back down and move to the right of the screen toward the Moes behind a wall. Destroy the wall and retrieve another key. Now move all the way to the bottom of the area and open the last gold wall to find the exit.
Destruction of both spawn points reveals a couple of pressure plates that opens the door. Inside are several spawn points and numerous enemies. Try to take out of the spawn points at first. Once the enemies are gone command 4 mob members to stand on in each of the claws of the giant dragon. This raises stairs of gold. Take the stairs on up to the dragon's eyes. Send Maggie inside the right eye. Press two red buttons to open the dragon's mouth. Enter the mouth and face three phases against the dragon sisters.
During each phase of the boss fight Homer has to float up and bop Patty and Selma on the head. Just watch the flight patterns and hover in the area where it flys the most. In between the 2nd and 3rd wave is an egg wave. Have Homer run through the eggs to destroy them. If any egg remains it turns into a Moe.
