Question about Samsung Digimax S500 Digital Camera
"Effect" spinning button broken
This is a problem with the "Effect" button on my s500. This is the spinning button on the top. I can't use all the functions. I'll set it to Program, and it will go to the Auto setting and I'll set it to Manual but I get the Children setting. How can I fix this?
    Genius:
  • 2,985 Answers
Check that it is doing all that it says in the manual and that you have not misread somewhere. If you are convinced that you are correct then Samsung customer support. It may be you will have to live with reduced functions or buy a new camera.
Posted on Aug 01, 2007
SOURCE:
Hoover 550MA top loader tub starts to vibrate when spin starts and bang into the sides also touches the top.Noticed a rip in the top plastic cover of the tub. The load is balanced and not overloaded.
The top rubber gasket stops water splashing over the top, it also gives some deadening effect in spin. You need that replaced and also check the balance springs and shock absorbers. They do break, come dis-attached or fail.
Nov 29, 2016 | Hoover Washing Machines
How do I replace a broken start switch
Washer Start Button Replacement -GE Top-Load Washing ...
? 2:05
https://www.youtube.com/watch?v=tEVwT4mL9ZU
Sep 27, 2012 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacingthe start button on a GE top-loading washing ...
Cabrio Washer Start Button Broken Quick Fix - YouTube
? 5:54
https://www.youtube.com/watch?v=h1CRcehOCxY
Mar 23, 2015 - Uploaded by FreidasGarden
This video is about Cabrio Washer Start Button Broken QuickFix. I hope it helps you get some wash done
Nov 28, 2015 | Washing Machines
My washing machine fill up properly but doesn't begin spinning. I changed the timer 7 months ago and was well.
does it wash though? if not its ur water pressure switch. other wise check ur door switch and motor coupler or broken worn belt. Also a bad clutch will effect spin?
Mar 07, 2015 | Washing Machines
My washing machine drains,but when on a cycle the drum doesn't move at all and it doesn't go into spin mode?
Check the actuator for the lid switch to make sure it isn't bent or broken. To find the lid switch, look for a pin on the lid that goes through a hole in the top of the machine when the lid is closed. The lid switch actuator is under this hole. If you can't see the actuator lever through the hole, it's probably bent off to the side or broken off. It's also possible to see it, but it's bent down to far to be actuated by the pin. If the lid is bent or the pin is broken off, that would have the same effect.
Apr 04, 2012 | Washing Machines
Why kithenaid top load washer won't spin. Any ideas on how to troube shoot the proplem?
Hi
The washer is not spinning maybe due to motor not running or due to frozen pulley or broken belt. To confirm where the issue is check if the motor is running, if motor is running then its due to broken belt or frozen pulley. Remove the back lid of the washer and check if the belt is broken or disengaged. If belt seems to be fine then check the pulley.
However, if all of these is fine then the door lid switch is defective and due to that the machine is not entering the spin cycle. Inspect the lid switch; its located is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. Please post back for any further assistance.
Daniel
Jul 24, 2010 | KitchenAid KAWS850L Top Load Washer
Images have pink overlay
I had the same problem with my camera, suddenly the LCD and picture shows some pink image overlay bands on the top usually. When focusing the bands sometimes disappear. But they always shows on image as on the LCD. Canon seems to fix this problem as goodwill (guarantee is not valid anymore) so I sent my camera to service for this. Hope they accept this otherwise it is broken, LCD common problem. (Solution or same problem we will see)
Dec 01, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Video
Switch the dial on the top of the camera to the picture that looks like a film square from a movie and then when you are ready to start video taping just press the button that you use to take pictures. Then when you are done taping, hit the same button again.
Oct 17, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Doesn't turn on
Customer support at Samsung it may be fixable under warranty- because I do not know what effect Play station would have on a camera.
Dec 25, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
21 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
