Question about Cornea CT 1810 18.1" Flat Panel LCD Monitor
Power supply lost power supply, I know I need to get a wall wart but I don't know is tip negative or positive? thanks.
  • michael stine Dec 10, 2007
    where can i find power supply for cornea 1810
  • 97 Answers
At the adaptor input on the device there is a small diagram that shows the polarity of the tip and the shield of the connector. If it is not there, check the information plate on the back of unit. It has the model/serail number on it as well as the power consumption and build date.
Posted on Jun 25, 2007
  • 432 Answers
Bs more specific with your problem.
Posted on Jun 24, 2007
SOURCE:
I need to know the original polarity setting and can't find it anywhere
I just took apart a hard drive enclosure which didn't come with a wall wart, and traced the wires on the power jack to the filter capacitor on the board. Sure enough, one side was labeled negative, and that was connected to the plug's outside. found a power supply that fit, and it works.
Oct 26, 2015 | Seagate Backup Plus 3TB 3.5" Black Desktop...
My Casio ctk 811ex wont power up anyone more.Is there an internal battery that needs replacing ? What could be causing the problem ? 2 weeks ago it was working fine
ALWAYS start with the "easy" things 1st. Is the AC outlet on the wall working properly? Is the "wall-wart" power supply working correctly? If no defect is found, check the DC power jack located on the rear of the keyboard. Does it seem to be loose or does moving the power supply jack up/down cause any change? New wall-wart power supplies can be purchased from Radio Shack and usually at a lower price than the original factory replacements.
Mar 29, 2015 | Casio Music
Midiman multimixer
If there's no polarity indicated on the connector on the unit, it's likely an AC supply. Many of these units use a 9V AC supply.
Jul 17, 2012 | M-Audio MIDIMAN MultiMixer 10 10-Channel...
I need power supply for Broadband
This router uses a 5 volt 2.5 amp power adapter.
You can download the manual from this WEB site and the specifications for this unit is on the last page.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000000300.pdf
Jun 12, 2012 | Linksys Wireless-G WRT54G Router
Worked great for years. Now, won't turn on. Plugged in and all connections checked. Light at on switch does not turn on.
Next step would be to check for power from the wall wart (external power supply). Note the output voltage indicated on the power supply, then check for that approximate voltage with a multimeter.
A replacement power supply can be found at most electronics retailers. Make sure the polarity matches, ie positive tip or negative tip, and the plug must match dimensionally. Make sure a replacement can supply the current that the original did (rated in milliamps - MA, or amps A). Ideally an exact replacement would be best if that is the issue. Be careful, and don't crack open that power supply!
Mar 07, 2011 | Dell Powered Subwoofer Set A425 Computer...
Sharp Aquos LC-37d40u made a clicking sound as it ususally comes on, then made the same sound and never came back on. No green light at the bottom of screen no power what so ever.
That sounds like a dead power supply. Smell it to see if it stinks like it overheated.
There are 4 13v connector pins that can be spliced into from one standard spliced wall wart.
Common is negative if you study the mobo by scratching off the paint. Both fuse tracks for instance are positive, there are two more positive pins.
Feb 06, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
External power problem
It's actually the opposite. 1/8" jacks are almost always positive tip. I think you are best off using a 9VDC supply. If the voltage is not staying constant at 9 volts it could certainly do damage. If the supply you used was a negative tip positive sleeve you may have burned out a component or two...and more voltage than recommended could have done some other bad things. If it does not work with a 9VDC supply with the correct polarity you can fix it yourself if you have electronic experience. You could also send it to me and I'll fix it at a reasonable rate.
Aug 26, 2009 | Ibanez Ts808 Vintage Tube Screamer Reissue
Coleman lantern fan am/fm radio
This lantern/fan/radio combination does not use/accept batteries. It is recharged using the black A/C adapter provided with the lantern. I hope you received the adapter with the lantern when you bought it @ the garage sale? You plug the adapter into the little circular opening just above the round spotlight on the lantern. Hope this helps!
Aug 22, 2008 | Coleman Lantern Fan Radio (841.321) AM/FM
Cornea CT 1810 18.1" Flat Panel LCD Monitor Logo
135 people viewed this question
Top Cornea Computers & Internet Experts
Ekse
Alun Cox
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
