Question about Blanco Ovens
How to unlock blanco oven
Oven does not work due to locking
5 Suggested Answers
  • 236 Answers
SOURCE: Oven Door Locked
is it locked in the up or down position?
Posted on Jun 04, 2007
vest6
  • 196 Answers
SOURCE: oven locked and I don't know how to unlock
To unlock the oven. Switch the beaker off for 5 minutes. This will reset the integrated system. Turn the unit back on and if it doesn't unlock, set the unit for self clean and let it engage. Waite about one minute and cancel the self clean cycle. This should unlock the door(s).
Posted on Jan 26, 2008
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
While baking oven starts broiling with no input from controller. f2 is displayed on screen
Hello there:
F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Sep 27, 2010 | GE JKP15 Electric Single Oven
My oven will not unlock.
Either unplug or turn the off off at the breaker. It may clear the problem. This happens a lot after clean cycles. Sometimes the electronics fry due to high heat, so try not to use self clean very often.
If this doesn't work, leave comments with your oven model and type of lock if you know. The instructions for opening a stuck lock depend on which type of lock you have: solenoid controlled buzz when setting or unlocking and have an arm you move to engage the lock. Heat sensitive locks have an lever you move to lock and un-lock, but don't make noises. Motorized locks don't have handles or levers, and lock by themselves. Thanks for your question, I hope the first instruction helps.
May 08, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
Model SVE 47600 - oven door remains locked after self cleaning
Called an appliance repair serviceman....after checking it out...turned out to be a sensor that actually burned up (first time using cleaning feature!!). The oven got so hot it actually burned the wiring going to this sensor. Pretty scary! The repairman said he doesn't trust the self cleaning feature...recommended doing it the old fashion way! He's had to repair many ovens due to the lock remaining locked. IF you do use the feature, he said to absolutely remove the racks first because they will slowly warp and you'll end up replacing them due to uneven cooking (i.e. lopsided cakes). It cost me nearly $200.00 to clean my oven! Could have had my entire house cleaned for that amount!!
Jan 27, 2009 | Jenn-Air JJW8430D Electric Double Oven
E1 f2 error
F2
Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked - If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
F2
Note: Also see fan thermal switches - Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
Good Luck
Sep 05, 2008 | GE Profile JT912 Electric Single Oven
GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Apr 09, 2008 | GE JKS05 Electric Single Oven
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
Oven lock engaging and disengaging
Unplug the oven from the outlet, and wait 24 hours or overnight, and plug it back in. It should unlock and work ok.
Dec 04, 2007 | Ovens
Missing manuel Code showing - F 2 -
hi,
F2
F2
Oct 31, 2007 | GE Profile JT912 Electric Single Oven
Ovens Logo
1,658 people viewed this question
Top Blanco Ovens Experts
shannon816
richie46
ray gallant
Are you a Blanco Oven Expert? Answer questions, earn points and help others
