Lost book for Delonghi quattro plus gas fire can anyone help
Can't get the cap off to get a new bottle
Thank you for your email my son got the cap off for us so all is well thanks once again
Posted on Jan 19, 2009
Fagor compact plus
You could have a defective gas control valve or a bad thermocouple. Also check the venturi tubes again. sometimes cob webs collect in them and it may be difficult to see unless you remove them and check.
Good luck,
Marty
May 05, 2014 | Water Heaters
I'll start from the beginning... 91 cbr250rr sat for over 6months then wouldn't start. Didn't have a choke so decided to put in new one while doing that decided to replace spark plugs and new leads, (had...
Is your choke working OK?..is there a spark at plugs take a lead of and put a good plug in the cap hold the plug against metal block to see if a spark is present use gloves or a pair of pliers to hold plug or u will get a big shock,this will olso check ur leads check each one in turn ,the firing order chud be in hand book
Oct 29, 2013 | Cars & Trucks
I have a new im65a pasloade nail gun that has only fired a couple of hundred nails and after standing for about 16 months the gun does not seem to be firing the fan comes on the green light flash the
your gas has expired , look at bottom of canister check the date. buy new gas also make sure cap on gas canister is down all the way till it snapps new gas doesnt come with cap down all the way
Apr 24, 2012 | Senco Air Tools & Compressors
Check engine light is on then every once in a while the light blinks about 5 to 10 times then stays in
You may need a new gas cap or air filter or a tank of good gas plus a bottle of injection cleaner
Jul 16, 2011 | Chevrolet Tracker Cars & Trucks
1997 expedition someone stole my gas cap the other day and i was woundering if i can just use anyone from any car to replace it?
  • I don't recommend using a gas cap not intended for your vehicle. If the cap does not seal right you can throw a check engine light and have some driving issues.
  • In a pinch many gas caps will work but an OEM spec manufactured one is $10 average.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 15, 2011 | 1997 Ford Expedition
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
My Delonghi gas oven takes nearly 45 minutes to preheat!
I would be suspicious of the thermostat. It or the sensing element may have failed.
Jan 28, 2009 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Jeep turns over but will not start
I am going to assume that you didn't accidentally put DIESEL in?? If you did, siphon all you can out and add fresh GAS(!) and 3-4 bottles Octane booster.
Squirt a bit of Starting Ether in the Air CLeaner inlet
Start Jeep
Squirt Ether
Start Jeep
Start Jeep
Squirt Ether
Start Jeep
Repeat until it runs. Do not use alot of Ether - will blow engine!!!
Fixed!
If you didn't put Diesel in, and KNOWING that the problems are usually FIRE-related, replace all FIRE-related parts ($40.00)
Get new ROTOR (Thingy that spins inside CAP, distributes HVolts)
Get new CAP
Get new cables (change cables to new CAP 1 at a time!!!) DO NOT RUN cables neatly. Cross them over each other in looms
Get New sparkplugs (Do not overtighten. Turn to seat snugly, then 1/4 turn more
Jan 17, 2009 | 1999 Jeep Cherokee
Quattro Plus heater will not stay alight
Does this unit have a thermocoupling?
If so replace it. (6 bucks)
It is the units flame sensor and they routinely go bad.
When they no longer sense flame the unit will shut off gas to the ignitor/burner.
It will only stay lit when you are manualy holding the button.
Dec 03, 2008 | DeLonghi Heating & Cooling
Heating & Cooling Logo
122 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
