Hi i have a macbook pro 13" that i bought 5 months ago brand new and did not get a reinistall disc for the os?how do i set back to factory settings so it was like when i bought it from currys?i have backed everything up with time machine and please bear in mind im still getting used to a mac as its the 1st mac ive ever owned?so is there any help you can give me please
Use Disk Utility to erase the hard drive. ... The process of resetting a Mac or MacBook tofactory settings gets rid of all your data ... This cloned drive can be re-cloned back to the main drive if you decide to restore your Mac, or it can be used to ... This means it will no longer be linked to your iTunes account. MacBook supportnumber 1 800 726 0294 Apple Technical Help
SOURCE: Macbook DVD drive
I wonder if the DVD is a faster disc than the Mac can handle. I know that when I use a 40x CD disc on a G5 optical drive, it's no go. But if I use a 4x disc, it's a happy camper. I bought an external drive to handle the faster discs.
SOURCE: lost install disc 1
you can down load it off the net but u have to put it on a dual layer disc for some reason for it to work
SOURCE: mac tune up software
Use ONYX instead. Better and complete solution:
http://www.titanium.free.fr/
SOURCE: Mac Book Pro forgetting Wi Fi settings
yep! Go to the Systems Preferences window and select NETWORK.. then select Airport and the advanced button... you can drag your networks to the order you prefer and then check the appropriate box at the bottom of the list to keep your log in ... that should do it!
As Verb75 says - you just need the right cable.
