Question about LG WM1814CW Front Load Washer
No power at all
Did a load of clothes then tried to do another and there is no response from the power button. electrical outlet still has power(checked)
  • LG Master
  • 17,130 Answers
Possible that the main controller has failed if there is power till within the power supply unit of the controller.
You need to probe into the power supply unit to confirm for a fuse failure, a link failure on the Low tension circuit, a failure to provide power to the controller.
Posted on Dec 31, 2012
2 Suggested Answers
  • 97 Answers
SOURCE: LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Posted on Jun 11, 2009
LG WM3455H won't turn on.
Unplugging to reset only works when the washer has power and on stand by. Start by checking the fuse on the noise filter, that is were the power cord connects to. If good than your main board is bad.
Apr 06, 2014 | LG Front Load Washer / Dryer Combo...
Press button dryer clicks but doesn't start
then it means motor is got jammed..
Mar 12, 2008 | Kenmore 63942 Dryer
Hello, the printer keeps saying alignment failure refer to device documentation for help...
Follow these steps to reset the product. Make sure you connect the product directly to a wall outlet and not a surge protector or power strip.
  1. Press the Power button (c01602202.gif ) to turn off the product.
    NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless.
  2. Disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the electrical outlet.
  4. Wait 30 seconds.
  5. Replug the power cord into the electrical outlet.
  6. Reconnect the power cord to the rear of the product.
  7. Press the Power button (c01602202.gif ) to turn on the product.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step two: Clean the electrical contacts on the printhead and inside the product The ink nozzles on the printheads might clog if you expose them to air for more than a few minutes. The ink nozzles also might clog if you do not use the product for long periods of time. Follow these steps to clean the electrical contacts on the printheads.
CAUTION: Follow these steps carefully to avoid damaging the sensitive electrical component
  • Make sure that the product is turned on.
  • Open the top cover of the product.
  • Press and hold the OK button for five seconds. The carriage moves to the left side of the product. Release the OK button.
  • Wait until the carriage is idle and silent.
  • Unplug the product power cord from the electrical outlet.
  • Use a dry, soft, lint-free cloth to remove any ink from the electrical contacts on the printhead.
    Nov 17, 2010 | HP Officejet Pro L7680 All-In-One Printer
    Washer door will not open. Power button will not
    You can manually unlock the door on this washer. First you should unplug the washer from the wall outlet and then remove the lower access panel. With the lower access panel removed, and the washer unplugged, reach up to the door lock and feel for a round release ring and pull it down. The door should unlock now.
    Thank you !!
    Jun 30, 2010 | General Electric WCVH6800J Front Load...
    I plugged the machine in, then pushed the power button, but theres no response at all. No lights on, nothing
    Check the breaker, if it is on, the electrical outlet may be bad or a wire on the outlet has come off. When removing the outlet check for a one of the wires not connected.
    Jan 06, 2010 | Washing Machines
    Jun 11, 2009 | LG WM2277H Front Load Washer
    Kenmore eilite oasis
    UL stands for an unbalance load where one side the tub is heavier than the other side.
    when the code is displayed, it automatically unlocks the lid so you can go in and reposition the clothes to try and balance it. once you are done, simply press the start button again and it should continue again where it left off. if you push the stop button, it will drain the water and assume the cycle is complete.
    unplugging it and replugging it in should allow you to do other wash cycles. press power and you should be able to select wash cycles.
    if you still have no control, make sure you still have power at the outlet by plugging in a lamp and turning it on. if no power, find the GFI outlet that controls that outlet and reset it. if not on a GFI outlet, then check the circuit breaker panel for a popped breaker. reset it and power should now be restored.
    Mar 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
    Printer doesnt switch on correctly
    Try the steps mentioned bellow
    Unplug the power cord from the All-In-One as well as the power outlet when there is still power in the All-In-One.
    Now with a lint free cloth and drinking water just moiston the cloth and clean the metal contacts of the ink cartidges and the inside of the printer where the ink cartridge get in touch with the printer contacts and leave it to dry for a while.
    Then insert the ink cartridges back.
    Plug the power cord directly to a wall outlet without surg protector. (if possible connect it to a different power outlet)
    Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
    until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
    Then check and see
    Good Luck
    Oct 04, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    Fisher Paykel Wasehr won't power up
    brand new???? call an authorized servicer. as long as your electric is good .all you can do
    Jan 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
    Fisher and Paykel gwl11 want power on
    Start of by replacing your drain pump. if there is still no response to the electroncs you will need another power supply. the pump took the electronics out. ???
    Aug 02, 2007 | Fisher and Paykel GWL11 Top Load Washer
    LG WM1814CW Front Load Washer Logo
    757 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
