Question about Fuji FinePix A360 Digital Camera
Zoom error Is there a quick fix for a zoom error -- Camera will not allow the lens to open and come out causing the zoom error -- Can not use camera Thanks
    Genius:
  • 2,985 Answers
No solution repair probably as expensive a replacement Contact Fuji the do a swap out at a discount service
Posted on Aug 01, 2007
SOURCE:
We have a message coming up saying "zoom error"
If the camera was operating properly before the zoom error then the most common problem to a stuck lens is dirt getting stuck between the two lens barrels. There are a few fixes for this none are guaranteed to solve the problem and should not be attempted if the camera is under any type of warranty. They include removing the batteries for a few minutes, reinstalling the batteries with fresh once with full power, turn the camera on while holding the the zoom button. Another method is to see if you can provide extra power to the focus motor by having the LCD screen turned off. There my be a button that allows you to switch from the viewfinder to the LCD screen switch to the viewfinder and try several times to focus (just point the camera at different distant objects) and attempt to focus the camera. I hope this gives you the results you need because the other suggestions may further damage the camera and are only a (last resort) thing. One is with the camera turned on tap the body on a counter or table edge while trying to zoom the lens obviously in the opposite direction to where it's stuck. The last is to gently push the lens in with the palm of you hand while zooming in. All these are just suggestions and carry no guarantee of working and may further damage the camera. The biggest cause of this problem is dust from a camera bag or some other environmental condition like sand from a beach.
Jan 24, 2011 | Fuji FinePix S1000FD Digital Camera
Fuji s5000 zoom error
Stop trying to zoom in and out. The gear is going to damaged by dust. Visit your service center dont warry. Its just a dust problem. THey will clean the lens zooming gear and fix it for you.
Thanks & waiting for your feedback
Jan 31, 2010 | Fuji FinePix S5000 Digital Camera
Fine-Pix A400 is showing Focus Error and will not allow photos to be taken. In addition, the lens will not retract when the camera is shut off. This problem occurred after using the zoom procedure several...
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Jul 22, 2009 | Fuji FinePix A400 Digital Camera
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Zoom not working E61:10
Zoom motor in camera lens mechanism is stuck due to **** etc. You need to open camera, take out camera lens section and check zoom motor.
Do the above if you know basic electronics and have little experience of camera repair.
If don't, contact Sony Service to fix the camera.
Nov 11, 2008 | Sony DCR-DVD608E DVD Camcorder
Lens error 0x2117 in Pentax optio E50
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Pentax Optio 50 Digital Camera
ERROR REMOVE CAP LENS
I had the same problem with mine after I dropped my camera when it was opening up after turning on. It feel directly on the lens and ever sense has told be to remove the lens cap.
I’ve disassembled the camera and discovered that the zoom motor drive assembly has a small set of plastic gears inside that are quite fragile and like mine are easily broken. You’ll find the zoom motor after taking the back assembly of the camera off. It’s located on the bottom left side of the lens assembly if you're looking at the camera as if you were taking a shot.
Here’s the part no. from the Panasonic support web site.....
L6DAAAHB0001
ZOOM MOTOR
46.07
May 28, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
I dropped my Casio EX-Z1000 on a tile floor. The camera turns on and the lens goes out and quickly retracts and camera shuts off. I can still view pictures on my card and can enter info on date, time, etc....
Unfortunitly when ever a digital camera is dropped it can cause the lens to come out of alignment this is what causes the error or problem. The len has several moving parts and can be replace most of the time it knocks the focus motor and zoom motor out of sync thust causing the lens to go out to try and post and sience the camera can tell the alignment is off then the lens goes back in. The repair for this should be around 100.00 I just got through fixing 2 of these for the same problem. Sorry but I hope this helps.
Mar 14, 2008 | Casio EXILIM EX-Z1000 Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Fuji FinePix A360 Digital Camera Logo
580 people viewed this question
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
