How do I reset my hot point wml 730 washing machine as it stays on one cycle and does not move to the next part of the program.
Jimster
  • 240 Answers
SOURCE: Hoover 600M washing machine cycle issue
Sounds like you may have a timer problem. You might be able to pick one up at a appliance parts center. Most of the time, they can be pretty pricey item, if you can even get one for older models. Check EBAY as well, sometimes you can find hard to find parts for pretty cheap. Replacing the timer shouldnt be that hard. UNPLUG the unit, remove the console, which should be held on by screws, the remove and replace one wire at a time back to the timer. Use caution when removing the timer knob, you dont want to crack it. Most knobs remove by unscrewing to the left.
Posted on Sep 05, 2007
  • 60 Answers
SOURCE: Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Posted on Sep 14, 2007
Buffalo12980
  • 625 Answers
SOURCE: HotPoint Top Loader model # WLW1500B
if you hear clicks then I'd have to say it was a mechanical timer. the timer has a small motor on it. a complete timer including its motor will run you about $120 but a replacement timer motor will be about $35.00
Posted on Sep 22, 2007
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
  • 4088 Answers
SOURCE: I have a Hoover 550 MB Top Loader washing machine
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Posted on Oct 20, 2009
Testimonial: "That is great advice . Will try and see if your solution works . cheers"
Bosch classix 1200 exprss washing machine will not move on from the wash cycle. it will keep on washing and never moves to the rinse cycle. pump and motor works ok.
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Mar 25, 2015 | Bosch Washing Machines
The conditioner is not being pumped through as normal on wash cycle? Is this a blockage that can be fixed easily? Cheers Steve.
Do the cheap things first. Remove the top and check the supply hoses for blockages or kinks. Get a length of springy plastic to thread down the hose to see if there is dried residue. When the top is off try a cycle that uses conditioner and see if it tries to empty the tray.
Dec 29, 2014 | Hotpoint Washing Machines
I want to stop a programmed cycle and start a new one at beko wml 15062 yl
I alsi have that machine. To stop on program and start another, I've pressed the play/pause button for a few seconds, then waited for the key light to come on. Then I switched to the program I wanted and pressed play/pause again
Jan 26, 2014 | Washing Machines
Hotpoint WML 730
Possible this seems to be an error. You need to start by check the inlet water flow, check the free flow, if not check the inlet valve or the valve drive. Also check the drain pump and see if there is no clogging, Now switch on and check voltage on the inlet valve, if absent check the main program controller. If water flows check
Nov 21, 2013 | Washing Machines
Hotpoint wml 730
use hotter water.
Sep 20, 2013 | Washing Machines
I have no power to a Hotpoint Aquarius washer, Model WML 730. Is there a line fuse and if so where is it?
Chance is its the two pole off/on switch or door interlock , check switch first.....
Mar 03, 2011 | Washing Machines
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine
Check pump fiter and pump.
Jul 22, 2008 | Zanussi ZJ1217 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
