Question about JVC Video Cameras
JVC GR-FX12E NOT WORK
Suddenly i began to reel tape and rip it camera began to tear the tape
  • 153 Answers
SOURCE: Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Posted on May 26, 2008
SOURCE: transfer movie from mini tape to computer - JVC GR-D770U
All you have to do, is make sure your computer has a FireWire card in it, and get a cable and hook it up it will automaticalty reconize the device and open up windows movie maker.
Posted on Oct 23, 2008
SOURCE: JVC GR-DX67EK MINI DIGITAL VIDEO CAMERA
I have the same problem. can anyone help?
Posted on Jun 28, 2009
  • 7 Answers
Product called EasyCap, for about 15 bucks, "can be found online" Has USB plug. Use your cable that has the 3.5 pin that goes out to rca cable, yellow, white and red. EasyCap has the RCA to USB then to computer. Use Windows Movie Maker, comes with XP & Vista, capture while playing from there. I just converted about 20 full tapes from one cannon mini 8 and 15 from a jvc dv onto a TB drive.
Posted on Jul 29, 2009
mastertech48
  • 149 Answers
SOURCE: JVC mini GR-D23EK Unit in SAFEGUARD mode E03 how to correct it
Hello. What I've found is that in dealing with the error codes your choices are very limited. You can try removing the battery and power supply for a while. This might clear the code, however, failing at that you'll be forced to send in the unit for repair--you are absolutely not alone in getting this type of problem--definitely get a quote first and keep "do I want to replace this unit" in the back of your mind....This is a JVC problem.---Rick
Posted on Sep 16, 2009
When in play mode the following error appears E03 Remove and reattach battery unit in safe mode
As you have already removed the battery and re-attached it, try to clean the contacts between the battery and the camera.
I had tried this and it did not work so I tried Tapping on side of Camcorder ( gently on palm ) and I worked, after 2 or three times while message appeared.
Below are few reasons what causes E03 Error
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with each other, the tape is not wound because of overload to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette having no tape inside.
6. The tape slackens and no pulse is produced until the slack is taken up and the tape comes into the normal
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 05, 2011 | JVC GR-DVL100 Mini DV Digital Camcorder
My camera is reading an E3 code and eating my tapes
Could be your reel has a problem or capstan gear is broken. To confirm if gear is broken, apply power to your camera and eject the cassette housing(with or without cassette) and take a look at your idler gear(found at the center of supply and take up reel) if it is rotating. It must rotate momentarily and stop. Good Luck
Mar 09, 2010 | JVC GR-AXM17U Camcorder
GR-DVL320 keep getting E03 error indication. Ejecting and reinsertion of the tape does not seem to be fixing the problem, also says unit in safeguard mode. What do I do to remedy this?
to the mechanism.
Sep 02, 2009 | JVC GR-DVL320 Mini DV Digital Camcorder
Getting error "E03 unit in safeguard mode" on JVC GR-D200U video camera
to the mechanism.
Nov 24, 2008 | JVC GR-D370 Mini DV Digital Camcorder
I have a JVC Compact VHS video camera, model GR-AX800 and it's beginning to eat my tapes. There's an error code, "E08" appearring in the viewfinder. Can you tell me what that means? ...
Either a belt has broken internally o is sliping enough to prevent the takeup reel from turning. This unit needs service. This is not a repair I would suggest you attempt unless you have worked on cameras before. The parts cost for this repair should not be more than $10. Check around for a service center that will work on JVC camcorders.
Dan
Aug 01, 2008 | JVC Cameras
JVC Digital Video Camera - model GR-D290
In the case no REEL FG is produced for 4 sec-onds
or more in the capstan rotation mode af-ter
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
SLOW/STILL mode.
each other, the tape is not wound because of over-load
to the mechanism.
status.
Jun 03, 2008 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR DVL 9000 digital video camera EO3 problem?
In the case no REEL FG is produced for 4 seconds
or more in the capstan rotation mode after
SLOW/STILL mode.
to the mechanism.
status.
Sep 16, 2007 | JVC GR-DVL9000 DV Digital Camcorder
Eo4 error code
HI SIR the fault is caused either by the take up or supply reel in the camera they are not rotating when the tape is inserted.maybe A defective tape or hung reel brake can cause this issue.or maybe a bad loosen guide of the tape path is lame , Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. thanx and plz try to rate and remember i am here just to help u thx
May 08, 2007 | JVC GR-SXM920 Camcorder
EO4
Something is causing either the take up or supply reel in the camera not to rotate when the tape is inserted. A defective tape or hung reel brake can cause this issue. Try replacing the tape, if this does not resolve the problem you may need to seek professional service to have the reels checked. Good luck my friend, Joe Weibel customelectronics.org
Jan 25, 2007 | JVC GR-FXM270A VHS-C Analog Camcorder
Frustrated
E03            TU & SUP REEL FG
SLOW/STILL mode.
to the mechanism.
Dec 09, 2006 | JVC GR-D290 Mini DV Digital Camcorder
Video Cameras Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
