Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer won't power on
I hit the start button and it powers on but then immediately shuts down.
  • tfrassetto Jan 18, 2009
    Thanks for your effort. I tried this but it still resets and shuts down. I am frustrated since the washer is less than 1 week old!
  • jperlmutar Jan 19, 2009
    I had mine serviced for the same problem on and off 4 times...they told me there was nothing wrong with it and that I should switch to a less sudsy detergent!!
    Well, now for the fourth time, it won't work. I am calling for service again and am a smidge irritated.
Push in the end of cycle button hold for a few seconds
Posted on Jan 18, 2009
Tip
Whirlpool duet sport
Problem: you have stopped cycle before it is done and now the unit will not start. You can press power on and select cycle but when you hit start unit powers down.
Solution: power unit on, select a cycle hit start...before the unit powers down hit pause cancel and you turn the washer off before it can turn itself off. The unit should return back to normal. This usually solves your problem without having to replace the control board.
on Dec 22, 2009 | Washing Machines
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a Whirlpool Duet Sport (model #WFW8400TW03) that shuts down when I press start. There are no error codes and the last cycle ran with no issues. The door is shut and seems secure. I can find nothing...
I had the same problem. My control lock was on without the status light on. To unlock the controls I Selected and held END OF CYCLE SIGNAL button for at least 3 seconds. The lock/unlock control status light never indicated the locked position, yet my washer now works. NOTE: Select and hold END OF CYCLE SIGNAL button for 3 seconds to toggle between lock and unlock.
May 18, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet Washer not starting
when you hit start button does your washer makes one beep and go off ? if yes i think it is your main control board need to be replace.
Jun 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer will not start.
if you want to replace your washer you need to talk to lowe's store manager nobody else he or she will replace your unit. other wise you call for service. i think your washer need new main control board. good luck.
Jun 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer won't start
whirlpool duet dryer has power but will not start--when I press start, it beeps once and the sensing light comes but the dryer doesn't start
Nov 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet
try hitting pause cancel twice if that doesnt work turn the dial around all the way to off try to unplug the washer if all that fails the remove the three torx screws remove the lower panel and reach up where the latch is after unpluging the washer on the bottom of the latch is a tear shaped tab pull it down till it clicks that will unlock the door
Mar 30, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
GHW9100LW1 W/POOL WASHER
if dorr does not lock then the fault is door interlock
Dec 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
205 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
