Question about LG DR-4912 DVD Recorder
After Recording Hi The next day after i have recorded something on my DVD recorder it makes a type of grinding noise at the back of the player. It will turn on and everthing works , but this noise goes on until you give it a smack then it comes rigth. Have you got any advice thanks
  • 97 Answers
Unit sounds like it has a small cooling fan at the rear. A bad fan bearing will produce a noise when dried-out. Replace the cooling fan.
Posted on Jun 25, 2007
SOURCE:
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting ..you will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
When I try to record a show. There is no picture on the disc when I'm done. Its just a white noise screen. I finalize the disc too. there is no prompt to tell me to format the disc.
If the disc playes back then the problem is not with the DVD unit. In order to record white noise, the channel selected for record is probably not tuned in. Try recording the same channel on to video tape and see what results you get.
Mar 09, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
My Panasonic dmr-es35v has decided to cease recording, and makes loud grinding noises, any ideas, reset?
You can try a reset, but I doubt it would do much good. The loud grinding noises and failure to record sound to me like the DVD-RAM drive has had it. This sadly is not a cheap part to replace, and there's the issue of fitting/alignment/firmware upgrade etc.
Uneconomical for a model that is over 4 years old (since it has no digital tuner).
However, if you are prepared to spend a small fortune on a workshop repair/replacement DVD drive, go ahead, but I warn you it could cost as much as, if not more than the price of a new VHS/DVD recorder combo unit.
Feb 10, 2011 | Panasonic DMR-ES35VS
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
Panasonic DMR-ES40V VCR won't schedule record: Recently, the VCR will not do scheduled recording anything beyond today. I can schedule a recording and it appears OK (I get red light on panel), but I never...
I found this solution on one of your old notes (but a different machine). I set up a scheduled record for 11:59 PM to 12:01 AM for the current day, then set up the scheduled record for the next day. The VCR recorded both the initial 2 minute session and the later one which I wanted to record.
Dec 27, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Mechanical Noise in Drive
hii..please go for a change in belt.
thanks..
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
**DISCLAMER**
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
DMR-EH75V DVD Recorder
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
Problem with reading and playing dvds
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 07, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Panasonic DMR-ES15
Just unplug it and let it sit for half an hour. Then try playing the lens cleaner disc, the problem would be fixed....
Sep 10, 2007 | Panasonic DMR-ES10 DVD Recorder
LG DR-4912 DVD Recorder Logo
177 people viewed this question
Ekse
