Ac charger wont work
My zeepad charges with the usb plug but not the ac plug
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Get a usb wall adapter
Posted on Dec 31, 2012
5 Suggested Answers
jonb3838
  • 237 Answers
SOURCE: AC Power adaptor wont work without usb printer connected
Hey alberto,
First off thanks for choosing Fixya.com. The Ac adapter itself could be bad or it could be the dc jack. And also the problem with your cpu fan could also be that the fan has gone out or the motherboard itself needs to be replaced.
Posted on Feb 15, 2009
  • 4234 Answers
SOURCE: wont charge
The most common cause of this is the input jack being broken off of the mother board. There is a fair amount of stress on the jack which is surface mounted onto the motherboard. It is common for the connection to break off. This can be fixed easily by anyone that works on surface mounted equipment. Please note that the laptop will need to be dis-assembled to gain access to the area that needs repair. This is a fairly involved process and should not be attempted by someone not familiar with laptops. Expect to pay around $100 for this repair. No parts should be required.
Dan
Posted on May 05, 2009
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Posted on Oct 12, 2009
hch2011
  • 458 Answers
SOURCE: runs on battery only wont
Computer power probems are traceable to batteries, ac cables and power outlets. First, the computer batterie should charger fi were situated appropiated in the compartments without ac cables power cord malfuctions.
Posted on Jan 28, 2011
Will my zeepad charge threw my pc. charge light has come on but zeepad has not
You cannot use a computer USB port to charge a tablet, unlike charging a smartphone. You will have to use the supplied charger. If you really want to use the USB port to charge your Zeepad, you will need to custom-built a cable using any extra USB cable you can spare. Just change the connector at the remote end of the cable to one that suits your Zeepad's 5V DC IN socket. You are forwarned the connector is not easy to find.
Jan 12, 2015 | Red Tablets: Zeepad 9XN Dual-Core 1.5GHz...
Why wont my zeepad turn on
Check the battery is charged - it may be duff and nee replaced if it is not charging or your power adaptor may not be charging it - check it with a multimeter - the power socket on laptops andf tablets are very susceptible to damage - if that fails then plug it into a pc using the usb port - it will charge very slowly as usb only has a very low charge current but be patient and if it charges up after 12 hours using the usb method you will know one way or another whether its the battery or the power socket or charger.
May 10, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
I have had my zeepad on the charger for a few days now and it is not fully charged. What do I need to do for it to recharge?
Probably, the ac charger unit isn't good anymore. Output charge voltage& current isn't sufficient to drive your battery charge beyond 80% threshold.
Change or replace this with a new one (same ac charger specs please) and charge your tab again.
Oct 09, 2017 | Tablets & eReaders
The charging port is not working on my zeepad 7.0
both of my charging ports on my zeepad are TOO LOOSE and wont make contact anymore, i need both ports so i can repair it myself, im so disapointed in the quality of the charging ports, one is a usb aanother is a skinny pin type...I really need the ports from someplace..
Aug 09, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
I have a problem with one of the the charging plug ins
The socket will need replacing. A computer repair shop will do it. Is there a standard round pin charger socket?? If so you'll need to purchase a charger for it
May 30, 2013 | ZEEPAD Tablets & eReaders
My zeepad 7.0 battery is dead
Hi, Zeepad battery is PBS01SHz10 is a japanese battery, similar to nokia BL-5k battery.
Open a zeepad is easy, the problem to find these kind of battery. I am thinking in change the internal connector to adapt the nokia n86 battery, is more easy to find almost here in Venezuela.
Apr 03, 2013 | ZEEPAD VIA8650 Android 2.3 Tablet
Charging the mp3mp4 player
  1. Get a USB wall charger. These are AC adapters that plug directly into the outlet. You then plug the USB from your MP3 into the port on the adapter.
  2. Charge your MP3 player on the go. There are also charging kits that plug into the cigarette lighter or power plug in your car. These kits come with a DC power adapter that has a port on the end for you to plug in your MP3.
  3. Acquire Apple iPod specific chargers. When you need to charge your iPod music player through an outlet, look for the Universal USB car charger or the Universal USB travel charger made specifically for Apple products.
Make sure that you have your player on a power strip or surge protector so that if you get a surge you wont fry your player.
Sep 27, 2009 | Audio Players & Recorders
Using USB in car as external power
the unit uses power EQUAL to what it is being charged with, when plugged into the USB.
you need to leave it on the DC (cigarette lighter) charger overnight to charge it fully, or use an AC plug for the Motorola Razor (min-USB) to charge it in the house
Feb 12, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Magellan Maestro 4250 wont charge
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
Dec 03, 2008 | Magellan Maestro 4250 GPS
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
