My panasonic cf-18 wont starts. it starts normally, but it holds to the point of "press for setup. and when i click on nothing happens and it does not respont at all.
  • 113 Answers
Your hard drives are not detected open cabinet removes cables which connects from mother board to hdd blow air clean the cables with cloth then reinsert in the respective slots it will work
Posted on Jan 13, 2010
  • reddy Jan 13, 2010
    your hard drives are not detected open cabinet removes cables which connects from mother board to hdd blow air clean the cables with cloth then reinsert in the respective slots it will work
Panasonic CF-18 wont turn on but power light comes on
Have you try cleaning and reseating the connectors, specifically the battery, the hard disk, and (next will be easier when you'll get the hand on a CF-18 Service Manual http://www.toughbookdrivers.com/drivers/cf-18/), the memory board, and the display ?
Nov 14, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Irql not less or equal blue sreen cf-51
reformatting the disk / restore computer back to company settings...is only the resolution for this...
To reinstall your operating system, you must have a CD drive in your multimedia pocket.
Note: CF-51 (Mk2) and CF-51 (Mk3) can also boot to an external Panasonic USB CD drive.
When the laptop is first powered on, the Panasonic name appears in white lettering with the phrase 'Press F2 to enter Setup' directly below it. When this phrase appears on the screen, immediately press F2 on your keyboard. Put the Panasonic recovery CD in your drive and use the arrow keys to move to the boot tab. Change the order of boot so the CD drive boots first. To do this, highlight the CD drive and press F6 until CD drive is the No. 1 listing. Press F10 to save your changes, exit and follow the instructions when your CD starts running.
Jun 14, 2011 | Panasonic Toughbook CF-51 Notebook
I Turn on my computer and it boots up normally until I get to my main screen. It shows my wallpaper but nothing else. My start menu and everything is not there. I tried to boot in safemode and the F8 key...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or you might try
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
once you have your computer running
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps good luck
Jan 06, 2011 | Panasonic Toughbook CF-29 Notebook
When I start my panasonic toughbook all I get is the panasonic name and then a blank screen
Try to reset hardware first:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
If it remains same, restart and tap F8.
If you get an menu, select safe mode and press Enter
See if it able to start in safe mode.
Mar 10, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
No sound due to reformatting the laptop cf-18
Go to Panasonic's website and click on service and support then driver. when your on the right page type in your model # for your pc then download the right driver for yourlaptop
Jan 05, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Need to disassemble
to remove the keyboard on the cf-18 keyboard you must remove the 4 screwsby the ESC, F4, F10, and PAUSE key. once removed lift the 2 covers and holding the keyboard from Function key sides lift up slowly. There are 4 sticky tapes holding the keyboard, once some of the tapes are off you can slide the keyboard up towards the LCD to remove. The connector to the keyboard can be removed by removing 3 screws from the aluminum center cover found under the keyboard
Jul 17, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Cf-18 toughbook
The BIOS may not support the larger drive at all; I suggest you look for a Toughbook forum and repost there and check Panasonic's site for a manual download and possibly a BIOS upgrade if the unit is equipped with a flash BIOS.
Aug 27, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Setup password
i think the computer is asking for bios pc if it is bios then you have to open the case and remove the bios battery for five sec.before this you have to remove the power plug.after five sec. just resit the battery and put the power plug back and switch it on.
plz post your findings
Apr 23, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Computers & Internet Logo
David Payne
David Payne
