Question about Health & Beauty
Troubleshoot propert kitchen scale
Scale keeps indicating error message after new batteries have been replaced
r321567499
  • 74 Answers
SOURCE: ERROR message
This link allows you to troubleshoot directly with the company...I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: Error message ErrL
My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
Posted on Feb 20, 2009
fitnessbalan
  • 59 Answers
SOURCE: My scale came up with an error message of ErrL
here is the contact information for conair
http://www.conair.com/-cn-18.html
Posted on Mar 21, 2009
awa13
  • 78 Answers
SOURCE: Salter kitchen Scales Model: 1041SVDR won't turn on.
This sounds very typical of kitchen and postal scales. I know you don't want to hear this, but this basically means it is time to replace your scale with a better scale - perhaps no longer giving Salter your business..
Posted on Mar 21, 2010
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
Need manual for camry ek2052 kitchen scale, gives err messge. Already replaced the battery
WARNING INDICATORS
1." Lo" Replace Battery
2. "err" means that scale is overloaded
Sep 07, 2017 | The Health & Beauty
Propert scales manual
didn't get a solution
Nov 03, 2013 | Home
Propert digital bathroom scales
remove battery. leave out for an hour then put back in. memory wiped then.
Oct 05, 2013 | Televison & Video
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
Taylor 7532S, battery replaced, error message 0-Ld
Try to reset the unit. Use the following steps
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
When setting Tanita scales specifics, after set, I get an error
I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
Mar 26, 2009 | Tanita BC550 Innerscan Body Composition...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Error message ErrL
Jan 28, 2009 | Conair Weight Watchers Glass Digital Body...
Health & Beauty Logo
95 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
