How do i remove the bulb from a gaf 2100r slide projector
Bulb blew out. don't know how to get it out. doesn't seem to pull straight out. also is there a replacement bulb? sylvania dat 400w 120 v
The bulb pulls out. You don't want to twist it, because it is seated with one big pin in the middle and four smaller ones around it. The big pin in the middle has a fin on it, to make sure you get the others in their right places.
To get the old one out, you want to remove the metal housing for the lens that surrounds the bulbs. Pinch the sides that are next to the open end of the housing a little bit and jiggle it. It'll come out fairly easy. Once that is out of the way, you can get a good grip on the bulb and pull it straight out.
As for new bulbs, you can find them on the Internet. The best price I last saw was for $27.
Posted on Dec 07, 2013
5 Suggested Answers
  • 412 Answers
SOURCE: I have on old GAF 1680 Slide Projector (carousell
Try contacting: www.micro-tools.com They have an amazing inventory of parts for projectors and cameras !!
Good Luck !!
Posted on Jan 29, 2011
  • 412 Answers
SOURCE: My problem is with a
I agree! The problem is a short in the remote or the socket the remote plugs into!
Posted on Feb 11, 2011
SOURCE: I just dragged this projector out of my
There is usually a sliding tab on the side of the projector (behind the handle) that toggles between "manual" and "automatic" advance. (Some models will have a couple of pre-set advance settings between "manual" and "automatic." These usually advance the slides every three to ten seconds.) Push the tab to the manual setting--this will allow you to use the buttons towards the front of the machine to advance your slides.If moving the tab doesn't work it may be broken or jammed.
Posted on Jul 31, 2011
  • 412 Answers
SOURCE: kodak carousel 760h projector
Neither of the "trademarks" you mention were used by Kodak, so the lens must be a non-Kodak lens. First of all, remove the lens and look along its side - it should have a rectangular "rack" (dimensions of the "rack" are roughly 1/2 inch by 3 1/4 inches) with gear teeth that will connect with the corresponding gear (inside the projector) on the focus knob shaft. If the lens does not have this "rack", then you should try to find a lens that does. (One source for lenses is www.VineValleyImaging.com). Verify that the lens is on the focus knob shaft and does not appear to be damaged. If the gear on the focus shaft is damaged (or slipping) you will need to contact a Authorized Repair Dealer to see if parts are still available for your specific model. Let me know if you need anything else! Good Luck !! Jim
Posted on Oct 25, 2011
Old automatic slide projector
Make sure that the wires are in and to make sure the button is on, if it is then wait a while. That doesn\'t work, then its just broke!
May 27, 2013 | Office Equipment & Supplies
Shift gear light is out on 94 ls 400
Hello
You need to pop up the wood surround up. Be careful. You have to pry up the back side (near the cup holder and slide it back. There's two pieces of plastic that the wood slides into in the front and if you don't slide it out you'll break those (I learned that the hard way). The piece will still fit fine though even if they are broken and it won't be loose. Anyway. after that is out there the plastic piece that the ect switch is in. Pop that up, there are clips again, no slides. I believe you have to remove the switch from the plastic. No big deal just pry it out easily. Remove the plastic screw and there's your light bulb. I found my replacements at radioshack. They're not exactly the same size but they work just as well. To get at the gearshift light, just reach under the left side, find the two wires going into that area, grab the plug, twist and pull out. Don't try prying the top panel off (the one with the Letters and Numbers) it will break. That bulb is a tiny wedge bulb. Just pull it straight out and do everything in reverse to put stuff back together
Jun 25, 2012 | 1994 Lexus LS 400
How do I change my projector lamp?
Instructions
  1. Front Projector
    • 1 Disconnect the power cable from your projector. Allow it to cool for 30 to 60 minutes. Lay the projector upside down on a table.
    • 2 Remove the lamp cover, typically located on one of the rear corners of the projector's underside. Depending on your projector, you will either have to loosen a few Phillips screws or press on one or two plastic release tabs to remove the lamp cover.
    • 3 Loosen the screws holding the lamp assembly in place. Grab the assembly by the handle and slide it out of the projector.
    • 4 Slide a new lamp assembly into the projector. Don't touch the glass on the bulb because it will damage the bulb. Tighten the retaining screws on the lamp assembly and replace the lamp cover.
    • 5 Turn the projector right side up and reconnect the power cable. Power on your projector.
    Rear Projector
    • 6 Unplug the TV from the outlet. Let it cool for 30 to 60 minutes.
    • 7 Remove the lamp cover. On most rear projection TVs, the lamp cover is located on the right or left side of the TV's rear panel. Remove the cover by loosening the screws and pulling the cover away from the TV. Certain manufacturers, like Mitsubishi, have the lamp cover in the front of the TV, near the left speaker. To get to the cover, you must first use your fingers to pry off the front panel below the screen, revealing the speakers and lamp cover. Loosen the screws on the cover and pull it away from the TV.
    • 8 Remove the lamp assembly. Loosen its screws, grab the handle and slide it out of the TV. If you have a newer Sony model, there are no screws. Instead, press the release tab to unlock the lamp assembly and slide it out of the TV.
    • 9 Slide a new lamp assembly into the TV. Don't touch the glass on the assembly, as the oils in your fingers will damage the bulb. Tighten the screws or pop the retaining tab into place.
    • 10
      Replace the lamp cover and front panel, if necessary. Plug your TV back into the electrical outlet and power it on.
Tips & Warnings
  • Touching the lamp assembly before it has cooled can cause a nasty burn.
Read more: How to Change a Projector Lamp ' eHow.com http://www.ehow.com/how_7307928_change-projector-lamp.html#ixzz1rpURlpva
Apr 11, 2012 | Office Equipment & Supplies
Kodak carousel 760h projector
Oct 25, 2011 | Kodak Carousel 4600 Slide Projector
I don't know how to change the head light on my 1997 Jeep grand Cherokee. there doesn't seem to be any screws to loosen the light.
Hi Clint,
I just want you to know that you are not crazy or blind!
The reason you cannot find any screws is because you are dealing with a snap-together vehicle.
If you only want to replace the bulb, you can reach around the radiator support and twist the bulb retainer to remove it and the bulb. If you are wanting to replace the ENTIRE headlamp assembly, follow the instructions below.
REMOVAL
Grasp lower edge of headlamp lens and pull straight back (away) from Grille Opening Reinforcement (GOR) . Disengage lower adjuster pivots from lens assembly.
Grasp upper edge of headlamp lens. Pull straight back (away) from grille opening reinforcement (GOR). Disengage upper adjuster pivot from lens assembly.
Rotate bulb lock ring counter clockwise. and remove ring and bulb from lens.
INSTALLATION
Replace by seating the assembly in the lamp housing and turning the lock ring 1/8 turn clockwise to secure.
Align upper adjust pivot into headlamp opening and snap into place.
Snap lower adjuster pivots into place.
Oct 16, 2011 | 1997 Jeep Grand Cherokee
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
I have a sears easi-load circular tray 9985 for a slide projector. I don't know what brand projector it will fit in. Thanks.
I have a number of these. The printing on the box is as follows:
For use with Sears 9833, 9843, 9853, 9854, 9883, 9884, 98833, Sawyers, GAF and Anscomatic tray-loading projectors.
Apr 30, 2011 | Cameras
How do I open my Gaf Hush-a-matic Slide Projector 2100E? I want to put in a reel of slides and can't figure out how to do it.
Push in the little red buttons on either side and pull forward. It might take a little doing but it'll come open.
Mar 04, 2011 | Cameras
Open Questions:
305 people viewed this question
k24674
