Question about Electrolux Washing Machines
Ewf1282 wont fill, replaced water solenoid valves!
rpbuice
  • 161 Answers
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Posted on Jan 08, 2009
  • 159 Answers
SOURCE: Samsung washing machine J1045 water over filling
This sounds more like the inlet valve is being supplied with constant power when its not supposed to be.This is normally due to the old valve spikeing the PCB & now you are getting constant power supply to the new valve.I think PCB needs to be changed as well.OE error was an after effect of the machine over filling.
Posted on May 25, 2010
  • 1606 Answers
SOURCE: The cold water fill valve
The websites for most of the major appliance manufacturers have parts diagrams for their products in the support section. Once you get the part number from the diagram for your model, you can do a web search for it. I usually end up checking five or six dealers before I find a reasonable price, and there is sometimes as much as 40% difference between dealer prices on some parts.
Posted on Nov 27, 2010
richroth
  • 9472 Answers
SOURCE: I have a GE WPRE6150K1WT top load HE washer. I
The volts are correct. Did you turn the water back on?
Posted on Jan 07, 2011
heatman101
  • 43501 Answers
SOURCE: electrolux ewf1282 wont fill with
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Jul 10, 2011
Short wash light and spin light on and beeping but machine wont agitate or fill up with water. We have just replaced the main power panel
check for obstructions on the water. if there are no obstructions then check wiring connections to both water supply solenoid valves . if connections are fine , then change the solenoid valves.
Mar 02, 2016 | Washing Machines
How do i fix e5 on the dishwasher
Three common causes.
  1. Defective solenoid water inlet valve
  2. Plugged water inlet filter
  3. Defective stop valve located where the inlet hose connects to the water line.
Problem 1 usually no water will enter. It usually works or not.
Problem 2 and 3 the situation is the tub begins not to fill and over time the filter closes completely or the stop valve plugs completely.
If you open the door after the fill cycle and you have not heard the unit fill it is most likely the fill solenoid. Partially filled need to look at the stop valve. The rubber washer of the valve deteriorates and loosens relocating over the hole plugging the water from going through. When you try to shut off the valve it in most cases will not close water tight. You can replace the stem and washer if you can find the same hardware type.
The solenoid replacement can usually be axcessed from the front but requires a skilled technican.
26051739-3tozjaopshvuyndb2zxhmboi-4-0.jpg Solenoid valve below
26051739-3tozjaopshvuyndb2zxhmboi-4-2.jpg Hope this helps?
Jan 13, 2016 | Dishwashers
My washer wont fill up or spin on spin cycle. its not a front loader
SOUNDS LIKE A BLOCKED HOSE SOMEWHERE OR OBSTRUCTION IN WATER PUMP
Apr 08, 2014 | Frigidaire Washing Machines
Hotpoint Super Plus 7821 dishwasher isn't drawing water, please help thank you
Hello
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
Water Inlet Valve
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 03, 2011 | Dishwashers
Electrolux ewf1282 wont fill with water
heatman101
Jul 10, 2011 | Washing Machines
Water line to automatic ice cube maker froze. now it wont fill tray
Your solenoid valve is passing water even when it's not energized. Clear ice and replace solenoid valve.
Aug 22, 2009 | Refrigerators
Ont stop filling with cold water
Hi. the pressure sensors in the water valve assembly appear to be damaged. you will need to replace the inlet water valve assembly in this case asap.
This is solenoid failuer. (basic water valve failure this case)
May 31, 2009 | Kenmore Washing Machines
Wont fill and agatate
sounds like the water valve check for supply taps make sure there on test solenoid's on valve for ohms Resistance or closed circuitif open replace water valve
Aug 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing machine wont stop filling up
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
Feb 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine wont fill
hmmm...wool requires cold water...I'm guessing that first the hot water and now the cold water solenoid valves have become clogged with sediment. test by turning off water. then loosen the hose connection to each inlet in back of washer. then slowly open water valves and let water pour into wash tub if hose will reach, otherwise pour into a bucket. if water comes out of hose, then look for metal screens at hose connections to washer and clean those. if still no water through solenoids (after re-connecting water hoses) then may need to disassemble solenoids and clean those too.
Oct 19, 2007 | Washing Machines
Washing Machines Logo
51 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
