Question about Belkin Computers & Internet
Belkin 54g wps button
Wps button
3 Suggested Answers
Tom Marvolo
  • 708 Answers
SOURCE: Can't turn on WPS on Belkin G model #F5D7230-4router
The version number of the router is not specified ???
Step 1 : Open RSP by typing 192.168.2.1 on the address bar of internet explorer
Step 2 : Check if there is the option Wi Fi Protected setup under wireless
Step 3 : If it is there Enable it and click apply changes
Posted on Jan 07, 2010
  • 36 Answers
SOURCE: belkin 54g wireless router
To reset your router to default settings, hold down the reset button for 10 seconds and realese it. Then unplug the power cord and plug it back in. This should work with most routers.
Posted on Feb 13, 2010
Where is the wps button on a N 1 Belkin route?
Using Wi-Fi Protected Setup
WPS uses WPA2 (described below) for encryption. It does not
provide additional security, but rather, standardizes the method for
securing your wireless network. You may use either the Push Button
Configuration (PBC) method or PIN method to allow a device access to your wireless network. Conceptually, the two methods work as follows:
PBC: Push and hold the WPS button located on the back of your
Router for three seconds. Then initiate the WPS procedure on the client device within two minutes. Refer to your client's documentation on this procedure. Pushing the PBC button will automatically enable WPS. The client has now been securely added to your wireless network.
PIN: The client device has a PIN number (either four or eight digits)
that is associated with WPS. Enable WPS through the GUI shown
below. Enter the client's PIN into the Router's internal registrar
(accessed through this GUI). The client will be automatically enrolled
into your wireless network within two minutes.
Oct 04, 2014 | Belkin (F5D8231-4) Wireless Router...
Can not log on to belkin 54g set up page
Few things you can try. First would be to do a factory reset. Do this by pressing the reset button for at least ten seconds. If that doesn't work you could try switching ethernet ports.
If that doesn't work your router is probably dead.
Apr 22, 2014 | Gateway Belkin 54g Wireless DSL/Cable...
Where is the WPS button
Here is the link to the router manual. Page 12 gives the loation of the WPS button. http://cache-www.belkin.com/support/dl/p74880-d_f5d9230-4_manual.pdf
Mar 02, 2014 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Does my belkin g plus have a wps button
Yes Belkin g wireless router have a wps button.
Jan 16, 2013 | Belkin Computers & Internet
Lost disk fo usb 54g can i get info from net
check here to see how to locate your model number:
http://en-us-support.belkin.com/app/answers/popup/a_id/381/
then go here
http://en-us-support.belkin.com/app/product/list/q/network-adapters
and choose "G" first under the blue 1, then select your model from the next list, then your version, (see the above link), then click the blue play button.
hope this helps!
Dec 05, 2010 | Belkin 54g Wireless USB Network Adapter
Belkin 54g wireless router
Feb 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Jan 04, 2010 | Belkin (F5D7230-4) Router (587009)
Password for belkin54g
If you cannot get the pass phrease from your friend then you will need to do a factory reset. This can usually be found on the back of the router. It will be a small hole and you will need to stick a paper clip or something similar into the hold and press the button down for approx 10 secs.
Good luck and if this helped please rate it.
Apr 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
I secured my wireless network but have forgotten the password
hey what you can do is you can reset the entire router... by using the reset button on your belkin router... Or else you can also access the router by using the following IP address in the internet exlorer...
try 192.168.1.1 or 192.168.1.0 & then go to the wep settings & reset the router or change the password for the router...
Jan 17, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Im trying to set security on belkin n router
Hi...if your router has WPS capability, such as a special button to set up wireless security, then to use it your client computer/device must also be WPS enabled.
If it is, there are usually two options to configure WPS security: the push button method, or the PIN number. The push button method usually requires that you press the WPS button on the router, then within a set time, press the equivalent button on the computer (eg laptop, or whatever device it is). The PIN number method requires a PIN to be entered into the client computer. The PIN can sometimes be found on a sticker on the router.
Your manual should help with the details, but see this page for some more info.
http://kbserver.netgear.com/kb_web_files/n101691.asp
If you don't have a WPS enabled computer or don't want to use it, you can set up security manually. Please come back to Fixya if you'd like help with this.
Dec 29, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Computers & Internet Logo
395 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
