Question about Creative Labs MuVo S200 MP3 Player
MuVoS200_PCFW_A5_1_02_02.exe wont turn on or do anything
How do i fix an application shell.exe error on a pkc0pc - 5.0 gps
your going to have to send it in if it want reboot thats all you can do
Jun 04, 2014 | GPS
I have a ASUS x501A notebook and when i upgraded to windows 8.1 after restart it goes up to the logon screen where it says welcome Bobby and that circle keeps turning and then after that a bright black...
When you reboot the machine, keep pressing F8. this should give you a menu to boot into safe mode. when in safe mode you should have an option on the charms bar on the right to refresh your pc which will restore it to previous settings without losing your data.
Oct 26, 2013 | Asus Systems Asus X501A Notebook
When I turn on the brand new Sylvania 07526, an error box pops up and says Application explorer.exe encountered a serious error and must shut down. It wont let me do anything. I click OK but nothing...
You have a bad harddrive, since the harddrive is an SD card (a storage card), it is defective.
Your best bet is to either return if for an exchange or a refund.
Jun 14, 2011 | Computers & Internet
A blankscreen always a blank screen....when i turn my notebook on, it wont show anything...just a blank screen
Blank screen with a Blinking Cursor or just the Blank screen?
Which is your Operating system?
What Program Did You Install That You Weren't Supposed To?
That information might help us.
One note: I recently ran into something similar to your issue regarding the "Windows Logon".. There are a number of malware programs which will rename the critical "winlogon.exe" file to something else like "winlogon2.exe".. The malware then replaces the renamed file with a trojan also named "winlogon.exe". So the "bad" winlogon.exe is working as a trojan while still allowing the "good/real" winlogon.exe to sit beside it.. (The "good/real" file has an icon which looks like a blue window with a yellow half-moon inside so it's easy to identify.)
In my case, I used the XP Recovery Console to scan through the files in C:\Windows\System32 and find both the bad and the good versions of the file.. I deleted the bad file from the Recovery Console and renamed the good file back to its original/correct "winlogon.exe".. Rebooting the computer allowed it to load Windows so I could run antispyware scans and finish cleaning up the computer.
It might be worth checking..
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 13, 2011 | Computers & Internet
My files on my desktop wont open up and most of my documents have all turned to short cuts - because of a virus called Fucox.exe - please if anyone has any idea as to how to remove this devil and restore...
This seems to be a pretty bad virus that won't let you do anything on the computer, so follow the instructions on this link. If you can install programs on your computer, follow only steps 7 and 8 from the above link.
Dec 16, 2010 | ASUS P5PE-VM Motherboard
CD KEY wont alow playback of movie
erase it and download VLC player it will play anything almost including your movies
http://www.videolan.org/mirror-geo.php?file=vlc/1.0.5/win32/vlc-1.0.5-win32.exe
Mar 17, 2010 | CyberLink DVD Suite 6 Essential for PC
Wont work or show icons or start menu
hi
this is not the fault of the graphics card explorer.exe is not running on the system you can manualy
run it by using a shortcut key of run and typing in explorer.exe and tapping run . this will work.
Nov 12, 2008 | XFX GeForce FX 5500 Graphic Card
Ntvdm.exe
boot to safe-mode - goto start then run and type msconfig -
Within Msconfig you should see a startup tab. Look in there and remove or uncheck all that appear to be using ntvdm.exe
Also check in start, programs, startup, remove anything there as well.
Let me know if that does not help.
G'luck
Oct 23, 2008 | Computers & Internet
Nextar ma715. need to somehow download video2smv.exe because the disc wont extract
http://nspiregear.com/download.asp
click on the link below the MP3 player/Video Player line.
Nextar and NSpireGear both use the SigmaTel Chipset in there MP3/MP4 video music player and you will notice that they are the same video2smv.exe. What you will download is a zip file named video2smv.zip.
Later
Nov 07, 2007 | Nextar MA7151B MP3 Player
Creative Labs MuVo S200 MP3 Player Logo
49 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
