Black and decker LED SL3WAKB light goes off
Light comes on and then just goes out. Hit trigger again and light comme on but out again in 2-3 seconds. I have 2 and both do and returned one but does it to.
bbtoast
  • 319 Answers
SOURCE: 2yr old Pioneer pdp-506 50" panel with seperate receiver unit
Hi Kricko
Your blinking light indicates an internal "board" issue. You should contact Pioneer Customer Service for initial help, but you will most likely need a TV repair shop to replace the part.
Good Luck
Pioneer (800) 421-1404
Posted on Jan 03, 2008
ZaneD
  • 41 Answers
SOURCE: Sony Bravia 40 inches has a defect
More then likely your power supply failed. If you do not hear a click from the relay during the power up cycle then your power supply failed.
Posted on Aug 08, 2008
  • 33 Answers
SOURCE: Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Posted on Dec 12, 2008
  • 1039 Answers
SOURCE: Screen on my Samsung LE32R87BD goes black for a
Contact Samsung . There is a software upgrade for this.
Posted on Sep 01, 2009
  • 668 Answers
SOURCE: My television turns on for about 2 minutes and
The lamp probably is bad and needs replacing. The part number is XL2400. I would replace it with a genuine Sony lamp.
I hope this helps,
Skyassoc
Posted on Dec 14, 2010
Black and decker pressure washer I pull the trigger water comes out for a few seconds then its like your constantly pulling the trigger on and off. it dies then fires back up and so it goes on and on.
Sounds like you have air in the system somewhere. When the same symptoms happened to me, I learned upon inspection that I'd inadvertently burnt a hole in the hose.
Apr 07, 2017 | Water Garden
Black decker cordless drill ldx120 runs for a second and shuts off, battery fully charged and the led light comes on and is bright.
The brushes on the motor may be worn . The battery may have several bad cells in it. The led lite only needs 2 volts for full brightness.
Jan 17, 2014 | Drills
Blender stopped working
Sounds like the motor burned out.
Jan 30, 2012 | Black & Decker Blenders
Light wont light up
The rechargable battery is dead, it has just enough juice to light the LED but nothing else. You can order a replacement battery from www.dewaltservicenet.com All Vector Products, Service and Parts are sold by Black and Decker which purchased Vector in 2006. The products are rebranded under the Black and decker name now.
May 19, 2010 | Vector 1 Million Power Series Spotlight &...
Charging light does not come on, is it working or not
usually not, but could be one of the LED light burnt out though I don't believe so. Do you have a volt ohms meter that you can check voltage coming from the charger contacts to verify the operation.
Oct 17, 2009 | Black & Decker Black And Decker 12 Volt...
L1, 2 and L3 versus COMM
what kind of light switch are you replacing??? assuming house light switch???
one way or two way switch??
I have not come across the type of switch before.
L1, L2 is just label as line 1 and line 2, comm is usually refer to common (ground wire-white).
is the red wire-hot???
Oct 23, 2008 | Electrical Supplies
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
