SOURCE: Error messege on startup
Read the information at the following URL:
http://www.instant-registry-fixes.org/how-to-fix-msvcr71dll-errors/
If this just recently happened (usually due to software install), try running a System Restore back to before you started having the problem.
Go to Start > Programs > Accessories > System Tools and click on System restore.
Follow the prompts and select a bold date back before the problem occurred. You will be prompted to reboot.
If you still have the problem after rebooting, you can try to fix corrupted Windows file by running SFC /scannow from a command prompt (you will likely need your Window XP CD).
If all that fails, boot to your Window XP CD and run a repair. You should not lose any data, but backing up is always recommended..
Let me know if you have questions.
Honest1abe
SOURCE: Microsoft Windows message: SOUNDMAN.EXE - Entry Point Not Found
install service pack 3 if that doesnt work then reinstall the OS in repair mode.
SOURCE: I disabled stuff in msconfig
I am glad you enjoyed fiddling with msconfig. Simply use the System Restore and go back a week before you played with msconfig.
SOURCE: rundll32 exe-entry point not found
Just visit this site...
http://www.fix-all-dll-errors.com/vmsvcrt.dll/
this will help in case of missing or downloading dll's .
helped in my prob. :)
