Question about Bosch HGS3052U Gas Kitchen Range
Bosch HGS3052U Gas Kitchen Range display
Display
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Bosch HGS5052U Gas Kitchen Range doesn't stop
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Apr 21, 2010
Finding a schematic for Bosch Gas Range
You will have to try requesting the diagram directly from Bosch.
Sep 19, 2016 | Bosch HGS3052U Gas Kitchen Range
Bosch Stove will not work
Is your power 50 cycles? If it is the electronics in the stove need 60 cycles. You might want to contact a local bosch dealer there to see if there is a board meant to work on 50 cycles.
Aug 08, 2017 | Bosch HGS3052U Gas Kitchen Range
Panel display doesnot work
it sounds like the display kit AP4929088 is bad and will need to be replaced. It will cause the problems you are having with the unit. Hope this helps. Is your Range still under warranty? it has some rules listed in the manual it maybe good for parts replacement for 365 days from purchase.
Dec 30, 2011 | Bosch HGS3052U Gas Kitchen Range
Panel doesnot work
it sounds like the display kit AP4929088 is bad and will need to be replaced. It will cause the problems you are having with the unit. Hope this helps. If you have purchased in last year, it may still be under warranty
I just converted from NG to LP on a HGS345UC DF the top works good the broiler runs OK also, However the oven has a heat shield over the lower burner with a large slot on both sides, When the oven runs a 2...
the oven orifice hasn't been tightened all the way down. sometimes it feels like it is down and tight so you need to look at the orifice and see if it's all the way down. if not tighten it some more.
Apr 05, 2011 | Bosch HGS3052U Gas Kitchen Range
I have a Bosch gas range Model: HGS346UC 0/1.
If the cooker has a digital clock it needs to be reset to manual or until 00.00 appears on display . To do this hold " - " button until the 00.00 is displayed .
Then press and hold the "+" and "-" buttons in both together at the same time until all settings have been cancelled . Try the oven now and it should come on.
Mar 26, 2010 | Bosch HGS 255 Gas Kitchen Range
Bosch oven model HGS3052UC doesnt close tightly, hasn't since new 3 yrs ago. any idea how to fix?
yesthis is a common problem with this brand. 2 things can be done. 1. replace the hinges left and right or add 3 washers on both sides of the hinge to bring the door hinges closer.Im a old bosch tech and I told them this was a issue.
Dec 27, 2009 | Bosch HGS3052U Gas Kitchen Range
OVER WONT HEAT UP
make sure the hose is connected to the propane tank and that the tank valve is opened letting gas into the grill exhausts... and then light the igniter but make sure the release valves on the grill arent on max... start it on low to med.
May 27, 2009 | Bosch HGS3052U Gas Kitchen Range
Bosch HGS3052U Gas Kitchen Range Logo
23 people viewed this question
Top Bosch Kitchen Ranges Experts
Oloyede Monsuru
Jim Thurston
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
